any suggestions on how to do a full cradle with the works drop ?
Drain coolant, remove fans, rad hoses, AC lines, unplug harness from vehicle and rest the harness on the engine, disconnect steering coupler from the rack, upper dog bones get removed, trans cooler lines disconnected, unbolt struts at strut tower, unbolt brake lines, unbolt engine cradle, lift vehicle really high, drag out engine and trans. Might have missed a couple small things but that's the gist of it.
thank you !!
