Thread: Top Swap!!!!
Results 1 to 7 of 7
  1. #1 Top Swap!!!!
    Mar 2015
    United States
    I have a 1997 naturally aspirated 3.8L i want to swap in a S/C what do i need besides, fuel pump, supercharger (of course), remapped or swapped ecu, i know i need an idler pulley that goes on the s/c but where does it go located?? and does the trans stay the same? or do i need to do a swap with that as well? all information is much appreciated!! Thank you!!!
  2. #2 Re: Top Swap!!!!
    heads and the lim. coil bracket, sc tensioner, l67 map l67 balancer.
    set of headers and a tune.
  3. #3 Re: Top Swap!!!!
    I wouldnt top swap on a 97 GT, the transmission is the issue.
  4. #4 Re: Top Swap!!!!
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    The trans stays, but since its a 97 you will also need to keep the vacuum line setup for it.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  5. #5 Re: Top Swap!!!!
    If you have a 97 GT best bet is to sell it for a 98+ car that is already supercharged. Or get a complete wire harness, pcm, engine and trans out of a 97 GTP.
  6. #6 Re: Top Swap!!!!
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I had a top swapped '97 GT, ran damn good, would bark the tires into 2nd at 50. Keep the fluid fresh, stay on street tires, and don't drive it like a complete idiot and you'll be fine.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  7. #7 Re: Top Swap!!!!
    May 2012
    Where winter never ends
    I have an entire SC top end sitting in my garage. Willing to sell. Includes the lim, SC, pullies, balancer, heads, valve covers. Ready to bolt on (could clean the parts). Came off a running driving car
    2000 Regal - Winter Beater
  1. Tuning Issues, 04 GT (L32 Swap / Gear Swap)
    By RivMan in forum PCM Tuning
    Last Post: 09-12-2013, 08:37 PM
  2. Engine swap or top swap
    By 06PONTGP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2013, 12:01 AM
  3. l67 swap, trans swap
    By MrPhotographer06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2012, 07:11 AM
  4. Replies: 1
    Last Post: 12-31-2011, 04:55 PM
  5. Fuel gauge dosnt work after wireing harness swap and motor swap
    By guimond47 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-02-2011, 06:01 PM
