Thread: complete engine tranny on engine cradle drop
Results 1 to 3 of 3
  1. #1 complete engine tranny on engine cradle drop
    Jul 2013
    Lockeport Nova Scotia Canada
    any suggestions on how to do a full cradle with the works drop ?
  2. #2 Re: complete engine tranny on engine cradle drop
    GrandPrix Junkie
    Mar 2012
    NC
    Drain coolant, remove fans, rad hoses, AC lines, unplug harness from vehicle and rest the harness on the engine, disconnect steering coupler from the rack, upper dog bones get removed, trans cooler lines disconnected, unbolt struts at strut tower, unbolt brake lines, unbolt engine cradle, lift vehicle really high, drag out engine and trans. Might have missed a couple small things but that's the gist of it.
  3. #3 Re: complete engine tranny on engine cradle drop
    Jul 2013
    thank you !!
  1. Installing new Tranny and Engine Mounts w/ Vinnie's cradle spacers
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2016, 08:20 PM
  2. Will the engine cradle out of a 97-03 work in a 04+
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 05-04-2014, 09:07 PM
  3. Engine Removal: Should I pull the engine or drop the sub frame?
    By acidcrashdburnd in forum General Tech Discussion
    Last Post: 03-13-2013, 03:29 PM
  4. W-body engine/tranny/cradle swap
    By gtpstyl in forum General Tech Discussion
    Last Post: 09-25-2012, 06:45 AM
  5. cracked engine cradle
    By bobbert88 in forum Brakes/Suspension/Chassis
    Last Post: 03-03-2010, 08:26 PM
