Thread: Questions on the Double Roller ....
Results 1 to 20 of 27
  1. #1 Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    So i did a rebuild on my Impala SS l67 and i have a few questions regarding the double roller, its used not new and had a little slack with the chain when i installed it and i wanted to know is that normal? can these chain have a little slack? Its not horrible or really bad i just want to make sure its fine i have no problem in tearing the front cover off and replacing it with a new one i used the chain on my old xp build but this build has the xpz and i know the xpz is a little more agressive then the xp thanks guys!!
  2. #2 Re: Questions on the Double Roller ....
    You'll break it.
    They suck.
    Ask me how I know.
  3. #3 Re: Questions on the Double Roller ....
    Buffalo
    Lol yeah total garbage You should remove it and I'll take for free and dispose of it for you
  4. #4 Re: Questions on the Double Roller ....
    Hippo.. it's ok man. Don't listen to these guys.
    But honsestly.. how many damn threads are you going to create about a double roller?
  5. #5 Re: Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    Only 2.. Lol i got a different car now... No more red gtp lmao... Hippo nameplate is officially taken away lls!!!
  6. #6 Re: Questions on the Double Roller ....
    I still don't know why he calls you Hippo.
    Must be that nursing home brain.
  7. #7 Re: Questions on the Double Roller ....
    Quote Originally Posted by blueguy View Post
    If you'd put down the crack for a second. You'd know he was driving the same car as hippo and asking the same questions
  8. #8 Re: Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    Lol @ you guys... Question whats a good timing to deal with? Or just get the same brand ?
  9. #9 Re: Questions on the Double Roller ....
    So everyone with a red GP should be named Hippo?
    Noted, audiinnie.
    Timing set? Ditch that crappy XPZ and get a stock timing set.
  10. #10 Re: Questions on the Double Roller ....
    Buffalo
    I have a brand new l26 cam I'm not using ..... Trade?
  11. #11 Re: Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    Noted, audiinnie.
    No
    Quote Originally Posted by crazyguy03 View Post
    Hell no
  12. #12 Re: Questions on the Double Roller ....
    Buffalo
    Ah c'mon That cam plus a stock timing gear set ..... Badass
  13. #13 Re: Questions on the Double Roller ....
    If I had a3800...I'd be all over that deal Bob
  14. #14 Re: Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    Why dont you use then lmao!!
  15. #15 Re: Questions on the Double Roller ....
    He wants to break it ...just like you
  16. #16 Re: Questions on the Double Roller ....
    So I guess Will @ Overkill and Dave @ Triple Edge using stock chains on their cammed cars are doing it wrong. Reptile has ran a stock chain on his Overkill custom cam as well, no problems.
    Noted.
  17. #17 Re: Questions on the Double Roller ....
    Banned
    Jan 2013
    maryland
    Lmao
  18. #18 Re: Questions on the Double Roller ....
    Noted.
    bingo im tempted to run st5 turbo cam on stock timing set too because lets be honest im far more likely to have catastrophic failure and break something else before chain fails lol. itll save me the drama of running a double anyways lol!!
  19. #19 Re: Questions on the Double Roller ....
    Buffalo
    But what valve springs ? And you said you didn't have the crank gear properly machined right?
    im running 105s and s1x no problems currently
    and curious though , who else broke a DR?
  20. #20 Re: Questions on the Double Roller ....
    i have 130# springs sitting in the basement with the st5 but id likely be better off running 150# springs from what ive heard others say.
    im faily certian jayrocas on 130# springs with that xpz cam.
  1. Rm double roller
    By BLUESMOKEGTP in forum Wanted To Buy - Parts
    Last Post: 04-14-2015, 03:30 PM
  2. Dampener with double roller
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2012, 08:15 PM
  3. Should I get a double-roller?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-21-2010, 11:20 AM
  4. which double roller
    By QwikGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-05-2008, 06:52 PM
  5. Double roller issues
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2008, 09:07 AM
