Thread: which double roller
Results 1 to 9 of 9
  1. #1 which double roller
    May 2008
    staten island,NY
    just as the title says, which double roller is superior?
    the rollmaster or the JP performance?
  2. #2 Re: which double roller
    Wichita, KS
    50/50 toss up.
    I have installed both, and they both are nice, but I still prefer the RollMaster with some additional machining done to them to add a chamfer on the ID of the rear of the gear. Pretty much I add like a 45* chamfer to the inside of the gear, on the end that bottoms out against the crank.
    After that...perfect fit every time.
    Still with both double rollers...I would still surface grind the oil pump cover down 0.020" from the inside for additional clearance, unless you measured and it clears just fine as your build goes. But rarely does anyone ever measure anything like this when they assemble or mod an engine. Most everyone thinks everything is plug and play with our cars.
    ~F~
  3. #3 Re: which double roller
    May 2008
    staten island,NY
    i was going to use the zzp milled cover. i picked up the xp cam with 105's, should i run the stock timing set or go for the double roller?
  4. #4 Re: which double roller
    Jul 2008
    Germantown, Maryland
    good info, I'll keep that in mind
  5. #5 Re: which double roller
    my jp is awesome. i use it on a rockered car even because i didnt want to get rid of it when i got rid of my cam. it fits perfect and i never saw any wear issues with it at all.
  6. #6 Re: which double roller
    Bastard Reptile's Avatar
    Kansas City, MO
    I've got the stock chain in mine with 105's...if I had to do it over again....JP.
  7. #7 Re: which double roller
    Barksdale AFB, LA
    Quote Originally Posted by Reptile View Post
    That's my plan.
    2009 Subaru Impreza WRX STI
  8. #8 Re: which double roller
    chicago
    x2 stock chain here also
  9. #9 Re: which double roller
    Jul 2008
    I can buy a rollmaster double for $60, has 500 miles on it.... I think I'm going to take it
  1. Those of you with double roller timing chains....
    By Reptile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2012, 11:49 PM
  2. Timeing a double roller setup???????
    By Andrew_99GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2008, 04:28 PM
  3. Timing a double roller?
    Last Post: 06-03-2008, 06:57 PM
  4. Double roller issues
    Last Post: 05-03-2008, 09:07 AM
