Thread: tach stops working and some misfire after crank sensor
Results 1 to 5 of 5
  1. #1 tach stops working and some misfire after crank sensor
    nj
    I have a 1997 gtp with a bit over 180,000. I noticed my tach would just drop to 0 while driving and the engine would miss a bit. After reading a bit It looked like the crank position sensor. I replaced it wed. I didn't drive much at all Thursday but today (friday) it's still doing the same. The tach stops responding and I'm getting some misfires here and there. The tach stays down till I shut off and restart but then it usually drops again while driving. Anyone have this issue... what should I look at next
  2. #2 Re: tach stops working and some misfire after crank sensor
    Did you use a AC delco replacement part??
    If not, I would only use ac delco.
    Otherwise inspect the entire harness going to the crank and cam sensor.
  3. #3 Re: tach stops working and some misfire after crank sensor
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    If it was an autozone sensor, that would be suspect #1 if I were troubleshooting. Delco or delphi only for that part.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  4. #4 Re: tach stops working and some misfire after crank sensor
    Bastard Reptile's Avatar
    Kansas City, MO
    I've used Borg Warner with no ill effects. You might want to make sure that the harness is routed correctly, and there are no exposed wires. They can get on the crank pulley and burn through easily.
    Also....get a crank sensor relearn done.
  5. #5 Re: tach stops working and some misfire after crank sensor
    nj
    Thanks guys. It was an advanced auto part. I'll try the ac Delco and the wires
  1. 98 GTP engine hits and tac stops working
    By tree501 in forum Engine
    Last Post: 07-21-2021, 02:20 AM
  2. Speedometer stops working in Neutral...
    By Booba5185 in forum General Tech Discussion
    Last Post: 01-11-2014, 12:23 AM
  3. Replies: 1
    Last Post: 01-20-2013, 06:15 PM
  4. Cleaned my throttle body..cruise control stops working
    By GTLGDP in forum General Tech Discussion
    Last Post: 03-21-2012, 04:31 PM
  5. rpm gauge stops working
    By pacothetaco in forum General Tech Discussion
    Last Post: 07-26-2009, 11:17 AM
