Thread: Boost solenoid causing KR?
Results 1 to 13 of 13
  1. #1 Boost solenoid causing KR?
    Slower, Lower Delaware
    Everything was looking good, no KR. I'm not sure what boost I was getting after putting on a larger MAF, larger injectors, and the Overkill PCM. I do remember I had no KR. A while after that I received an error on the bypass valve solenoid. I replaced that and everything seemed OK. I didn't check the KR after that. Last week I went to OC MD to do some street racing and 2 to 3 * of KR pops up. Could it be that when I first added the last upgrades my boost was a little lower than it is now because I fixed the BPV Solenoid and now I'm getting more boost and more KR? I didn't make any real changes other than that. Boost shows up now as 10 to 11.
  2. #2 Re: Boost solenoid causing KR?
    GXP Level Member
    Mar 2015
    Tomball
    Why would the solenoid lower your boost? I've been looking for information on its operation, but haven't had a lot of luck other than traction control, something else and I recently found out it will dump boost if there's some kind of issue with the engine control, probably as a way to save the engine from damage haven't figured that one out yet. I thought it was either on or off but could be PWM controlled I guess, but I'm not sure. So if you're either on or off I wouldn't see how it would change your boost level alone.
    Has the weather changed much since you last ran it that hard? Could the tune be ok in cooler weather and on the edge as its getting warmer out?
    Jeff
  3. #3 Re: Boost solenoid causing KR?
    The weather has gotten warmer. I thought maybe if the solenoid was going bad it might have let boost drop during my previous test. I don't know enough about it to know if it would have been on or off. I seemed to have boost when I got the error but I didn't check it. There's a video on youtude that shows a failed soleniod and the car has low boost but it has some.
  4. #4 Re: Boost solenoid causing KR?
    A bad soleniod can net you less boost. It simply doesn't allow all the boost.
    Weather can also effect things.
  5. #5 Re: Boost solenoid causing KR?
    Thanks Bill, I think I must have been down on boost the last time I checked for KR. I did no real mods since then. I did find last night my I/C was a little low on water. I filled that and will check it again today. I'v fixed a leak several times but it keeps returning. I replaced the hoses so maybe I've got it this time.
  6. #6 Re: Boost solenoid causing KR?
    Apr 2015
    Columbus, OH
    Yeah, mine is preventing boost too. I'm only getting 3-4 lbs with vacuum attached. If I pull the vacuum off I get 8. I have a bad wheel speed sensor too, track light coming on randomly. Got a new hub so going to try that first and see if traction control had anything to do with it. If not I have 2 more selenoids to swap out.
    Top Swapped 01 Imp
  7. #7 Re: Boost solenoid causing KR?
    GXP Level Member
    Mar 2015
    Tomball
    Could you guys explain how and what mode will cause low boost? Is it the geometry of the linkage that does not keep as much spring pressure on to keep it closed and allows leakage?
    As I understand it you have a 2 way valve that has an inlet and an outlet and exhaust on the other side. When the valve is open (don't know if it's NC or NO) it will direct pressure to the bottom of the BBV and cause it to open. When closed the inlet side is blocked and the pressure in the bottom of the BBV is let out via the other port on the valve and the little "filter" they have on there.
    I am not doubting you guys I am just curious how it works and this particular failure mode. I am used to only having spring pressure keep the valve closed and no means of opening it but manifold vacuum.
    Also how is it controlled? Is it simple on off or PWM?
    Jeff
  8. #8 Re: Boost solenoid causing KR?
    Apr 2015
    Columbus, OH
    I think you have it pretty well figured out. I didn't know how that vent on the selenoid worked, your explanation makes sense.
    If you don't have tuner, I'll post a picture of the tables later. Can't remembered off the top of my head, but I think there is traction, top speed cut, and duration? A couple others.
    Top Swapped 01 Imp
  9. #9 Re: Boost solenoid causing KR?
    GXP Level Member
    Mar 2015
    Tomball
    I don't have a tuner, I have only had my car for a little over a month or so, and I am just trying to get it to run as fast as it was stock. One of my sticking points is that the computer seems to be dumping boost on me all the time because of another issue. But I am just wondering how the valve could cause a lower than normal boost value. After I started thinking about it just now I could see if the valve is not seating properly and allowing boost to open the valve until it into equilibrium with the spring force trying to close the valve. Would this be a correct assumption?
    Jeff
  10. #10 Re: Boost solenoid causing KR?
    Apr 2015
    Columbus, OH
    Quote Originally Posted by J57ltr View Post
    Jeff
    You could always just remove the hose. That's the only way I'm getting full boost right now. Though I'd like to get mine working correctly too after the trouble of wiring it up.
    Top Swapped 01 Imp
  11. #11 Re: Boost solenoid causing KR?
    GXP Level Member
    Mar 2015
    Tomball
    05', Doesn't work tried that. The computer commands less throttle then throws the car in reduced engine power mode and shuts you out of the throttle. Sets it full rich and -15* timing until you shut the car off open the door (to kill power) and restart the car.
    Jeff
  12. #12 Re: Boost solenoid causing KR?
    Apr 2015
    Columbus, OH
    Jeff
    Oh. Drive by wire is a pain in the arse.
    So here's what's in the pcm for boost control:
    Top Swapped 01 Imp
  13. #13 Re: Boost solenoid causing KR?
    GXP Level Member
    Mar 2015
    Tomball
    Hmm, that cataylst protection looks promising. Boost ramp rate, is looking like a possibility too. Thanks.
    What does it take to set a code for the boost bypass valve?
    Jeff
    Sudden,
    My thoughts are that its warmed up and now you aren't losing boost maybe that is why you are getting KR. I'm not sure you would have to speak with your tuner.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Boost bypass solenoid
    By Xanthous in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2015, 10:12 AM
  3. Boost a bit low, how to test the boost bypass solenoid & actuator?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2014, 07:50 PM
  4. Boost Solenoid & Fuel Q...
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2009, 02:16 PM
  5. boost solenoid
    By tjvdubsport in forum General Tech Discussion
    Last Post: 05-27-2009, 12:24 AM
