Thread: Cleaned my throttle body..cruise control stops working
Results 1 to 18 of 18
  1. #1 Cleaned my throttle body..cruise control stops working
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    So you know i just took it off and cleaned it, put it back on, cruise control doesn't work for me now -_-
    My car has an endless supply of problems. Anyone know whats up?
  2. #2 Re: Cleaned my throttle body..cruise control stops working
    both cables on tight and in the same spot??
    3rd brake light burned out?
  3. #3 Re: Cleaned my throttle body..cruise control stops working
    Check that you didn't break the cruise cable. The end of it can be tricky for some to remove w/o breaking.
  4. #4 Re: Cleaned my throttle body..cruise control stops working
    GTP Level Member
    springfield IL
    3rd break light burned out will cause it not work...?? Wtf. Lol
  5. #5 Re: Cleaned my throttle body..cruise control stops working
    Troy OH
    TPMS sensor?
  6. #6 Re: Cleaned my throttle body..cruise control stops working
    Isn't one on his sig pic year
  7. #7 Re: Cleaned my throttle body..cruise control stops working
    Troy OH
    i see... used to being around cars that are still under warranty
  8. #8 Re: Cleaned my throttle body..cruise control stops working
    Oct 2011
    New Jersey
    Third brake lights still work, the cruise throttle line doesn't wanna stay on. It's not broken, its exactly how it was before i took it off. When i pull on the throttle it just falls right off. Am i doing something wrong? I'm pushing it on there but maybe not hard enough?
  9. #9 Re: Cleaned my throttle body..cruise control stops working
    it kinda clips in there. Thats the best way i can describe it.
  10. #10 Re: Cleaned my throttle body..cruise control stops working
    Are you talking about the end of the cable to the post or the cable isn't holding in the bracket?
  11. #11 Re: Cleaned my throttle body..cruise control stops working
    Oct 2011
    New Jersey
    The cable is holding to the bracket fine, its the end of the cable that doesn't seem to want to clip into place. I can push it on there but when i pull on the throttle it just falls right off. I might not be clipping it on correctly or pushing hard enough. Nothing looks wrong with the end of the cable either.
  12. #12 Re: Cleaned my throttle body..cruise control stops working
    Troy OH
    does the cable move alright? it's not broken way down somewhere is it?
  13. #13 Re: Cleaned my throttle body..cruise control stops working
    Oct 2011
    New Jersey
    Quote Originally Posted by Poil336 View Post
    I'm pretty sure its not broken. Sometimes ill get it on there nice and snug so when i pull the throttle it stays fine no matter how hard i pull it..Then i start the car up, drive and then when I'm done driving i open the hood up and realize it fell off..again.
  14. #14 Re: Cleaned my throttle body..cruise control stops working
    Sounds like the end broke. Grab yourself another cable from the JY and you should be all set.
    Jan 2009
    Tallahassee, FL
    Are you pushing it on or sliding it on? It slides onto that small post on the TB bracket. When taking it off you need to push it towards the intake and vice versa when putting it on.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  16. #16 Re: Cleaned my throttle body..cruise control stops working
    even if it's not fully clicked in..it'll hold unless it's broken. Sorry..
  17. #17 Re: Cleaned my throttle body..cruise control stops working
    Cruise Control?
    Pffft.
    I pedaled the blue car all the way to Iowa with poly everything.
    Numb leg, FTW.
    Grow a pair.
    LOL
  18. #18 Re: Cleaned my throttle body..cruise control stops working
    Oct 2011
    New Jersey
    It must not be broken, it hasn't fallen off yet the past two times i took it out..lets see if it holds
  1. Cruise Control Not Working
    By Curt7 in forum General Tech Discussion
    Last Post: 07-07-2011, 08:10 PM
  2. Why is my cruise control not working?
    By bronzegp in forum General Tech Discussion
    Last Post: 04-12-2011, 05:44 PM
  3. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  4. rpm gauge stops working
    By pacothetaco in forum General Tech Discussion
    Last Post: 07-26-2009, 11:17 AM
  5. Cruise Control stopped working
    By 98gpgt98 in forum General Tech Discussion
    Last Post: 07-03-2008, 11:48 PM
