Thread: HELP Not making full boost
Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
  1. #21 Re: HELP Not making full boost
    Apr 2008
    Chillin at the Beach , VA
    TDC, that's why your the man.
  2. #22 Re: HELP Not making full boost
    TDCRacing
    Guest
    I try lol
  3. #23 Re: HELP Not making full boost
    Jan 2009
    Knoxville
    i agree. you're the man!
    Ill send it to your address in a minute.
    Thanks again.
  4. #24 Re: HELP Not making full boost
    TDCRacing
    Guest
    No problem man. Glad I could help
  5. #25 Re: HELP Not making full boost
    Jan 2009
    Knoxville
    the problem is solved ( i think)
    i put on that boost bypass valve last night and now i have around 7.5 - 8 lbs peak boost.
    does that sound more like it?
    thanks again everyone. (especially tdcracing)
  6. #26 Re: HELP Not making full boost
    TDCRacing
    Guest
    Yep as long as you have the stock pulley then it looks like you're good to go.
    I bet it feels a little faster huh lol?
  7. #27 Re: HELP Not making full boost
    Jan 2009
    Knoxville
    actually looks like it is only making 7 psi.
    but yes, it is faster than 4.5 lol.
    what should it make with the 3.4 i've got coming?
  8. #28 Re: HELP Not making full boost
    ~10 psi, 11 when its cold. you might not even make that much, but the less boost you make on a smaller pulley the better because then you know your car is running well.
  9. #29 Re: HELP Not making full boost
    TDCRacing
    Guest
    Good rule of thumb is 1 psi per 0.1 pulley drop.
  1. Did the LIM this weekend, not getting full boost, and getting hot... wtf?
    By daniel981 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2008, 10:18 AM
  2. gas gauge stuck on full
    By 94GTRoyalty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-13-2008, 02:10 PM
  3. Full glasspack/steelpack exhaust?
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-19-2008, 05:38 PM
  4. should of bought the full size ic
    Last Post: 07-20-2008, 07:27 PM
