TDC, that's why your the man.
i agree. you're the man!
Ill send it to your address in a minute.
Thanks again.
the problem is solved ( i think)
i put on that boost bypass valve last night and now i have around 7.5 - 8 lbs peak boost.
does that sound more like it?
thanks again everyone. (especially tdcracing)
Yep as long as you have the stock pulley then it looks like you're good to go.
I bet it feels a little faster huh lol?
actually looks like it is only making 7 psi.
but yes, it is faster than 4.5 lol.
what should it make with the 3.4 i've got coming?
~10 psi, 11 when its cold. you might not even make that much, but the less boost you make on a smaller pulley the better because then you know your car is running well.
