Thread: Phenolic IC installed!! Pump location fixed!!
Results 1 to 10 of 10
  1. #1 Phenolic IC installed!! Pump location fixed!!
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Recently installed my Phenolic IC along with W-Body Store/ZZP FMHE. I'm pretty sure every one has their fluid lines routing the same way but I will double check here.
    As you see the outlet line (red) goes to the bottom of the IC pump.
    It then comes out the side of the pump to the IC core (most rearward line by alt)
    The line by the coil packs then goes down to the inlet of the FMHE by the passenger fog lamp.
    Seem correct?
    When I added fluid the pump was very quiet! Then out of no where it was screeming!!!!
    I popped the inlet line off at the FMHE (by passenger fog lamp) and ALOT of air came out and then the pump got quiet again.
    Added more fluid, cycled the pump a few times and no more bubbles were seen at my fill tube.
    Biggest question I have...?
    MUST I drop the pump down more to prevent any air? Or prolong the pump's life? It is hard to tell (in the driveway picture) but I relocated my horns to the cradle area by the passenger front tow hook.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #2 Re: Phenolic IC installed!! Pump location fixed!!
    Jul 2008
    Hooksett,NH
    This is an update!
    As seen I had to relocate the pump to prevent air bubbles. After moving it I got ALOT more air out.
    I also forgot to mention I had to modify my coil mounting point to clear the belt. This might help others.
    Initially the other day I took her for a drive on the 3.2 pully with no KR. So I decided to swap on the 3.0. God damn this think is loud coming from a 3.4 lol. I got a blip of .5 KR and am running an afr of 10.8 on the hit and tapers to 10.4 @ 16-17* of timing. I might lean it out a bit but I know i will be adding more timing.
    02 Regal GS
  3. #3 Re: Phenolic IC installed!! Pump location fixed!!
    Jul 2008
    Hooksett,NH
    Hey everyone. I really like Ed's product. But just be sure to RTV more to the left. Not right on the opening on the LIM. As you can see the IC didn't even touch that bead it and caused me a vacuum leak.
    02 Regal GS
  4. #4 Re: Phenolic IC installed!! Pump location fixed!!
    GTP Level Member buickman104's Avatar
    NYC
    Thanks for the update and tips! Hopefully I'll be intercooling this summer too!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  5. #5 Re: Phenolic IC installed!! Pump location fixed!!
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Is the core supposed to be crooked between the plates like that?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  6. #6 Re: Phenolic IC installed!! Pump location fixed!!
    Feb 2013
    Missouri
    Quote Originally Posted by 99GT2dr View Post
    Yes. I think his problem is it's a Gen V intercooler on a Gen III LIM. The untouched bead of RTV was directly under the fins of the core, not the plate. If you look at the pics you can see what I mean, the big square hole on the LIM isn't as long as the square hole (core) of the intercooler.
  7. #7 Re: Phenolic IC installed!! Pump location fixed!!
    Apr 2015
    Columbus, OH
    Aren't those beads kinda big? Or is that what you have to do with those intercoolers? A bunch of it on the sides looks like it squeezed into the intake opening.
  8. #8 Re: Phenolic IC installed!! Pump location fixed!!
    Cibolo, TX
    Quote Originally Posted by Booba5185 View Post
    Yes. I think his problem is it;s a Gen V intercooler on a Gen III LIM. The untouched bead of RTV was directly under the fins of the core, not the plate. If you look at the pics you can see what I mean, the big square hole on the LIM isn't as long as the square hole (core) of the intercooler.
    Well I was looking at some ebay pics, and apparently that's just the way these ic's are made, would definitely mess with my ocdness, lol.
    http://m.ebay.com/itm/121396442528?nav=SEARCH
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  9. #9 Re: Phenolic IC installed!! Pump location fixed!!
    Feb 2013
    Missouri
    That's the same IC the OP has, made by the guy in the for sale section, lol.
    http://www.grandprixforums.net/threa...erCharger-3800
    He has 2 designs, only making the second design now (like the OP has).
  10. #10 Re: Phenolic IC installed!! Pump location fixed!!
    Going to drop this here. Because.. honking my horn.. it's kinda genius and simple
    http://www.grandprixforums.net/threa...sy+intercooler
  1. Vacuum line routing..
    By Ridin ON Chrome in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2015, 07:48 PM
  2. Is my fuel line routing correct? Just top-swapped.
    By Runicdionysus in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-22-2015, 02:18 AM
  3. Power steering line routing
    By huttler in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2013, 05:39 PM
  4. looking for a vacuum line routing guide
    By Spazztic2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-28-2010, 12:02 PM
  5. 3.4 Installed, still have KR and high boost-now what?
    By Liquifire in forum General Tech Discussion
    Last Post: 10-25-2009, 08:51 AM
