Thread: Camp sensor code. New cmp sensor??
Results 1 to 15 of 15
  1. #1 Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Cam pos sensor was throwing a cel for being out of range. Doesn't kick the code driving only on start up. I'm going to try another sensor soon. Any ideas guys?
  2. #2 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Car is an 04 gtp comp g btw thanks
  3. #3 Re: Camp sensor code. New cmp sensor??
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Check the wires going to it first. A cam sensor isn't a five minute fix.
    Also check to make sure the harness that goes to it, the crank sensor and the oil sensor is plugged in all the way to your coil pack.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  4. #4 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Will do. I've been chasing this for about a year. First did the plugs/wires/and a coil. Still had a multiple misfire/cyl 2 misfire/cmp codes then changed the icm and now it's just the cmp code. Just changed the sensor the other day and before if I cleared it it would stay off for a few days then come back on now with this new one it comes on as soon as I turn the car on. It's getting irritating.
    I did read on this forum when I did a search that the code went away when people went from running hai or cai to stock air box. Doesn't seem right but whatever works. In running a homemade cai.
  5. #5 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    So I pulled the sensor out and looked it over and it looked fine. Still getting the damn code.
  6. #6 Re: Camp sensor code. New cmp sensor??
    Cam sensor should have nothing at all to do with a CAI. I could understand a MAF code from over oiling a filter and killing it. But not a cam sensor.
  7. #7 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    That's what I figured. What about a bad icm? Could that throw a cam sensor code?
  8. #8 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Could a bad ignition control module cause a cam sensor issue? I'm going to change out the cam sensor again this weekend and hopefully that will fix it..
  9. #9 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Just tossed a new cam sensor at the olé girl. Checked for codes with my torque app and nothing. So hopefully that fixed it. !!
  10. #10 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Unhooked the battery and hooked it back up after about 10 minutes and went inside and took a shower and came outside to go to work and started the car and the cel immediately came on for the cam sensor. But it does seem to idle alot better with this new cam sensor... I don't get it. Next trip is to a shop with a better scanner to try and narrow down the issue.
  11. #11 Re: Camp sensor code. New cmp sensor??
    need to leave it unhooked for at least 30 minutes, or longer, id do a hr to be safe if you got the time.
  12. #12 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    Really.? Does it do the same thing if I just clear the code with the torque app?
  13. #13 Re: Camp sensor code. New cmp sensor??
    using the t app it should be clear as soon as you re start the car. if it comes right back after clearing it, you still got a problem there.
  14. #14 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    That's what I figured... looks like she is going to the stealership to get scanned then.
  15. #15 Re: Camp sensor code. New cmp sensor??
    Jul 2014
    Belfast, me
    If I clear it after I start it it doesn't come back on til I start it again.
  1. Knock sensor code
    By pontiacGTP123 in forum General Tech Discussion
    Last Post: 02-11-2014, 08:53 PM
  2. oxy sensor code
    By cavell in forum General Tech Discussion
    Last Post: 08-19-2013, 03:29 PM
  3. Car bogs at low rpm And still o2 Sensor code
    By DrSnazzy in forum General Tech Discussion
    Last Post: 02-22-2012, 10:48 PM
  4. Can a bad O2 sensor cause a misfire code?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 08:01 AM
  5. Help w/ O2 Sensor code
    By MooseGundr in forum General Tech Discussion
    Last Post: 12-03-2010, 12:18 AM
