Thread: double roller timing chain
Results 1 to 6 of 6
  1. #1 double roller timing chain
    Sep 2011
    FLORIDA
    Installing a new rm double roller and speaking with the guy at zzp he says no need to chamfer the crank gear. Truly how true is that. Jus add the machined cover n thicker gasket and I'm good
  2. #2 Re: double roller timing chain
    Buffalo
    We should make a section dedicated to double roller threads
  3. #3 Re: double roller timing chain
    Nov 2011
    NY
    Quote Originally Posted by Crazyguy03 View Post
    Lol... There'd still be the same questions!
    OP, have you searched the topic? Is your crank gear pre-chamfered? Omg... And seriously, you ask the person selling you snake oil if it'll make your hair grow back along with make you rich!?!? Lol
  4. #4 Re: double roller timing chain
    Kemmerer, Wyoming
    lots of people dont do anything to the chamfer and are fine, other people are uncomfortable with the fit and chose to have it chamfered to match the stock crank gear. personally, I would rather have a proper fit and not have to worry about the offset that will occur if its not machined
  5. #5 Re: double roller timing chain
    Donating Users nascartech's Avatar
    Abbotsford, British Columbia, Canada
    you don't need machined cover and thicker gaskets just run double paper gaskets but use some gasket maker between the 2 layers thats what i did with mine and it works fine
    01 GTP is3 cam 130 springs double roller 60lb injectors lq4 maf headers 4000 stall lowered
    sold 97 GTP stock
    Sold 2001 gp gt ssm90 plog dp 3.8 208 whp 265 at the crank 14.8 1/4
  6. #6 Re: double roller timing chain
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    I had GR8racingfool chamfer mine as my local machine shops wanted to know the metal grade and strength. I will also be running the machined oil pump cover and 1 genuine gm front cover gasket.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  1. double roller timing chain
    By nascartech in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2013, 06:47 PM
  2. Roller Master Double Timing Chain
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2012, 08:28 AM
  3. help me with a double roller timing chain
    By foursixer in forum General Tech Discussion
    Last Post: 12-20-2010, 12:20 PM
