Thread: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
Results 1 to 12 of 12
  1. #1 Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    Mar 2015
    Connecticut
    I don't know the name of these two parts, but they're small cylinders, with a slot down the length of them (like a piece of metal folded into a cylinder.)
    I believe they were in between the LIM and the supercharger, and I believe they were just to help align everything when reinstalling. They aren't a critical part, are they?
    I forgot to use them, but the supercharger's already torqued down with the new gasket. Should I just leave it alone? Will the gasket be ruined if I take the supercharger off again, or will it still be OK if I haven't run the engine?
  2. #2 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    im thinking you'll be ok dont think people use them when a ic is installed.
    if you have not run the car, or not ran it long you could take the sc off and install them. gen 3 plenum gaskets are cheap if it tears on you.
  3. #3 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    Mar 2015
    Connecticut
    Thanks. It's not coming off if it doesn't have to. I gotta finish this weekend so my other car can go in for body work.
  4. #4 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    hangover park IL
    they keep the blower parallel and in line with the belt drive.
    ~James~ Psychotic Gearhead
  5. #5 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    May 2013
    RI
    Quote Originally Posted by Turbocharged400sbc View Post
    I agree and I think you should spend the 15 minutes now and put the dowels in.
    Greg
    2004 GTP Special Edition
  6. #6 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    HUDSON
    If you have too much trouble with brackets lining up, and supercharger pulley alignment. Eyeball the pulley and see it is lined up ok.
  7. #7 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    hangover park IL
    yeah just make sure you **** yer woman with an eyeball and not shove yer dowel into her hole. totally the same thing
  8. #8 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    Mar 2015
    Connecticut
    To be clear, these aren't the ones in the snout. I think they were in the LIM, and guessed they were just to help align the gasket and supercharger during reassembly. But everything's aligned without them, and torqued to spec. Just wanted to be sure they weren't required for some other reason, but I can't imagine they'd contribute significantly to "holding force" when there are ten bolts torqued down around the housing.
  9. #9 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    hangover park IL
    they dont contribute to "holding force"
    they keep everything in line while you tighten the bolts. with just the bolts there is significant slop. ive seen way too many cars that chew up belts.
  10. #10 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    Feb 2013
    Missouri
    I'm curious what guys do with intercoolers? I agree with you James, just curious about the proper way on I\Cs.
  11. #11 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    My ssic core fits over the dowels, don't they all?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: Forgot to reinstall supercharger "placement pegs" (?) leave it or reinstall?
    Mar 2015
    Connecticut
    OK, thanks, that's clearer than before.
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. LIM reinstall
    By YoungGTP in forum How To Write-Ups/Tech Tips
    Last Post: 11-10-2013, 07:59 AM
  3. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  4. Tranny reinstall help!!!!!!
    By blortz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-15-2011, 11:06 AM
  5. uninstall & reinstall LIM and SC
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 05:34 PM
