Thread: Tranny reinstall help!!!!!!
Results 1 to 20 of 21
  1. #1 Tranny reinstall help!!!!!!
    Calgary
    so i am reinstalling the transmission onto my engine before dropping the engine back in the car... i am having trouble lining up the trany and the engine so the tranny will not slide together..... ive already been at it for over an hour and it only has about 2 inches to go......
    advice would be greatly appreciated
    HELLPPP!!!
  2. #2 Re: Tranny reinstall help!!!!!!
    Charles City, IA
    Push the torque converter the rest of the way in, might have to rock and spin it a bit.
    SMGPFC Two Nipple General
  3. #3 Re: Tranny reinstall help!!!!!!
    Calgary
    the converter is bolted.... i cant get it to slide in any further???
  4. #4 Re: Tranny reinstall help!!!!!!
    Charles City, IA
    Un bolt it from teh fly wheel and push it back if the engine and trans are out of the car there is no reason they wouldnt fall together besides that
  5. #5 Re: Tranny reinstall help!!!!!!
    Calgary
    oh so i should push the torque converter on to the tranny and then bolt the torque converter to the flywheel???? and it should go on nicely???
  6. #6 Re: Tranny reinstall help!!!!!!
    SE Level Member Hixc's Avatar
    Lawrence MA
    i just did this yesterday in my car, put the torque converter inside the tranny, dont bolt it to the engine first, then line up the splines with the engines flywheel, push it together. after that you can get under the car and spin the torque converter where the flywheel shield is supposed to go to get it to line up with the flywheel holes. i had my brother spin the crank as i put each of the 3 bolts in on the flywheel. but once you get 1 bolt in and started on the engine to tranny, tighten it down to get the tranny to close gap, i also used it to kind of pivot the engine in place. carefull not to strip threads though. after that 1 bolt is in the rest seems to be cake.
    S1X, TOG, Trannyman Gen3, 3.0/2.8, 42.5#, 105#, Thrasher, Borla PRO XS, Magnaflow Cat, 1.6 roller rocker
  7. #7 Re: Tranny reinstall help!!!!!!
    Charles City, IA
    Yeah converter needs to be installed on the trans or you will never get it all the way on.
  8. #8 Re: Tranny reinstall help!!!!!!
    GT Level Member WHT98GTP's Avatar
    Monroeville
    ^ second that. Converter goes in trans first, then slide them together. When bellhousing is bolted, you can spin the converter through the starter hole and install the bolts on the flywheel. Piece of cake.
    *2002 Buick LeSabre Custom* Bronzemist Metallic * SS Headers *4" FWI*
  9. #9 Re: Tranny reinstall help!!!!!!
    This will be a laugh for the guys who have done it many times. Dunno why I was working on milkcrates laced with trans fluid etc. You know how it goes.
    Here's a guy...maybe me, tossing a TC in. Gives you the basics and shows you that some of them don't go perfectly easy. Part fo the trick is lifting with both hands..the milkcrate didn't make that easy. BTW you need to put about a quart or two of fluid into the converter before installing it.
  10. #10 Re: Tranny reinstall help!!!!!!
    PA
    [/URL]
    That took waaay longer than it should have
    2001 GSE
  11. #11 Re: Tranny reinstall help!!!!!!
    Lawrence MA
    i lol'd at this video, especially when my torque converter slid on almost like butter >.>
  12. #12 Re: Tranny reinstall help!!!!!!
    Sometimes they butter...sometimes they fight.
    I like to have a realistic video to show the newbies what can happen. As well as how not to struggle on a milky crate.
  13. #13 Re: Tranny reinstall help!!!!!!
    Lawrence MA
    idk maybee if it was because it was a brand new TC lol
  14. #14 Re: Tranny reinstall help!!!!!!
    I've had old and new go like butter and then others want to fight alittle. Think about what it is we are doing. Putting a floating item onto a fixed spline while also lining up the input shaft and pump shaft. That's rotating and lining up three things at once.
  15. #15 Re: Tranny reinstall help!!!!!!
    Calgary
    i didnt know you were suppose to put fluid in the torque converter????? i already got the engine adn tranny put back in my car.... nothing came out of the torque converter in the way of fluid?????
  16. #16 Re: Tranny reinstall help!!!!!!
    St. Louis
    That's because the TC is empty. It will fill itself once you start filling the trans. but you will have to fill, then start and run through the gears, then shut off and repeat until the fluid stays full. IIRC the converter holds like 4 quarts by itself. Maybe more.
  17. #17 Re: Tranny reinstall help!!!!!!
    Yeah, you can probably get away w/o filling. Every mechanic/trans guy I've ever seen/talked to prefills a quart or two at the least.
  18. #18 Re: Tranny reinstall help!!!!!!
    SE Level Member darkfox1009's Avatar
    May 2011
    Diamond Springs
    yeah, total I believe it takes 7.4 Liters to fill the TC and pan. I could be wrong though lol
  19. #19 Re: Tranny reinstall help!!!!!!
    Donating Users Kejross's Avatar
    Feb 2010
    Oklahoma City, OK
    I remember the first trans I tried to do without any clue what I was doing and left the tc bolted to the flywheel and then ruined the new trans trying to install it that way. I know better now and am down to about 5-6 hours from 4 days lol
    SOLD-98 4dr GTP, l32 Swapped, IS2 heads, IS3 cam, S2 intercooler, S3 FMHE, E85, 65# inj, N* TB w/LQ4, OBX Headers, Borla catback, 3.0 zzp mps, lc-1 wideband, HP Tuners, PRJ wires, FWI, Lowered. 04 GTO M6, 07 Grand Prix LS4 powered GXP. 98 V6 GMC SWB, exhaust, custom intake. 09 HHR (Wifes)
  20. #20 Re: Tranny reinstall help!!!!!!
    Calgary
    yeah i didnt fill the TC but i havent put the car into gear yet
    but the dipstick does say that it is up to level, that is before cycling through the gears though
    ... just working out a few tweeks with the new engine.... will post a video when she is all done....all new drivetrain parts, suspension, and engine
  1. LIM reinstall
    By YoungGTP in forum How To Write-Ups/Tech Tips
    Last Post: 11-10-2013, 07:59 AM
  2. 3.1 tranny on a 3.8?
    By vinny of destruction in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2011, 11:18 AM
  3. tranny
    By mcsddd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 01:01 AM
  4. uninstall & reinstall LIM and SC
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-12-2008, 05:34 PM
  5. Tranny???
    By Darkcelle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-06-2008, 10:36 AM
