At this point I would say keep it running and watch it and if it just starts bellowing clouds shut it down. Then start tearing it down again, pull the plugs and see if anyone is wet first. I throw a moving blanket folded in fourths over mine to get the rear plugs.
Is it possible that with the IC installed the Vacuum is higher and you have a marginal LIM gasket?
Jeff
