Thread: I think its cam time
Results 21 to 40 of 72
  1. #21 Re: I think its cam time
    I'd VS it.
    Those have good potential.
  2. #22 Re: I think its cam time
    Mar 2012
    NC
    Quote Originally Posted by 98BrokeMyCarVet View Post
    s1x in my car and love that cam! will be getting ported heads and maybe a m122/tvs from a gt500 depending on how the conversion plate comes along from the dude on thechicagogarage.com. then ill blow that up and finally buy a yugo.
    Fixed.
  3. #23 Re: I think its cam time
    ive got more parts than time thats for sure i have another engine already its sitting at my moms in the tboned car.
    seriously tho for the OP id consider the s1x from dsmuts.....
  4. #24 Re: I think its cam time
    Howell, NJ
    Quote Originally Posted by DrunkDiddler View Post
    I'd VS it.
    What cam did you have? It had a beautiful idle.
    Quote Originally Posted by WhiteLightningGTP View Post
    Cam all teh things
    Big cams
    For maximum lopes
    Question relevant to you also.
  5. #25 Re: I think its cam time
    Mar 2012
    NC
    Of the cams I've driven...stock, VS, S1X, XP, IS2, IS3...for overall SC driving crap...I'd go VS with 1.8 rockers on ported heads.
  6. #26 Re: I think its cam time
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Quote Originally Posted by Jomamma View Post
    NIC. Great sound, horrible fuel mileage, limited HP potential, powerband is kinda weird. I wish I would've put an XPZ/SSIC setup in it instead of putting the NIC cam back in it this winter, I kinda regret it.
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  7. #27 Re: I think its cam time
  8. #28 Re: I think its cam time
    Nov 2012
    Frankenmuth, MI
    i would spec a custom cam.
    Really, this is the smartest thing to do. You can't beat it, get exactly what you want, for the same price as a vendor cam..
  9. #29 Re: I think its cam time
    Howell, NJ
    I was thinking about that before I posted this thread, but I don't know nearly enough to decide on custom cam specs.
    I was even thinking of something with a low enough lift to keep my 1.9rr, but why bother.
  10. #30 Re: I think its cam time
    Feb 2009
    flintnasty MI
    It doesnt matter because its impossible to measure. Without oil pressure the lifter will just bottom out and your max lift will be a random number. A stock lifter will have almost .150 travel so ideally peak lift with no pressure is .100 on the cam and .190 at the valve on a 1.9 rocker.
  11. #31 Re: I think its cam time
    Donating Users Uno99's Avatar
    Appleton, Wi
    Yes!!! more rocker ratio lift travel blah blah. If you want a good DD cam and not have to spend more $$$ on valvetrain stuff to support it just go with the VS. Not because its what i have its just easy/less to support it. Not sure if you mentioned it. But whats the milage on the car now?
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  12. #32 Re: I think its cam time
    Buffalo
    Why vs not s1x/xp? To avoid changing the springs and seals ?
  13. #33 Re: I think its cam time
    Appleton, Wi
    ^^^I know where your going with this so just post whats on your mind and lets just help this guy make his decision. He also mention he is not gonna be reving up high so vs is a good choice.
  14. #34 Re: I think its cam time
    gardner,mass
    I love my vs, technically more power at half the cost. I ran a 13.5 1/4 on just the vs with a slipping trans.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  15. #35 Re: I think its cam time
    Appleton, Wi
    ^^^Was wonder when you'd chime in :-)
  16. #36 Re: I think its cam time
    Quote Originally Posted by Ginseng View Post
    Ding ding ding
    04 Comp G.
  17. #37 Re: I think its cam time
    I ran a 13.2 with a stock trans and an XP.
    With pump gas and a 3.4", too
    And it sounded cooler. Ha.
  18. #38 I think its cam time
    And how many of you guys actually get in the higher rpm range driving around town.. Unless your on the highway very unlikely, with stop and go traffic.. Go big they all say until you start having issues with drivability. Notice most of those big cam guys have other cars they DD... Then the added cost of 130lb/double roller etc.
    04 Comp G.
  19. #39 Re: I think its cam time
    Buffalo
    Shouldn't need a double /130s on a s1x or xp
  20. #40 Re: I think its cam time
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Here's my .02 cents, and I'm sure no one cares, but I'll say it anyways.
    *First off, I've never put a cam in my car and don't plan on it soon but I have ridden in cars with an aftermarket cam. What I'm going to say is based off opinion and research from what I've done.
    The VS cam has great potential and is one of the easiest, if not the easiest cam on the valvetrain. According to ZZP, it was designed for stock valvetrain, but I wouldn't ever do that nor do I advise it what so ever. From what I've learned, the VS cam has great potential in the lower powerband. Better for acceleration from 0-60+ (Don't quote me on this). Chris Hinson made a write up comparing the XP/S1X/VS cams and his overall "winner" was the VS because of it's potential and easy driveability. But all cams can be DD'd. Just ask Nick about DDing his Thrasher cam.
    If my research is correct and the VS is better for the lower powerband, I wouldn't get it for that reason. These car's have a blower on the engine, and are torque monsters. Going 0-60+ really isn't an issue for these cars. But highway pulls and these cars fall on there face, completely. So I'd get a cam that will yield more power in the upper powerband, such as the XP/S1X, compared to the VS. But it really all depends on where you're driving. Whether it's mainly city, highway, or a mixture of both. So my opinion is based of highway driving, since I do it everyday.
    If I were ever to spend the money/time on a cam, I would make sure it was worth my time. Even though the VS has good potential, I would want something "bigger," and I would most definitely want the choppy lope from a larger cam. I'd NEVER cam my car with something that doesn't lope. Defeats half the purpose for me even doing it lol.
    Once again, I probably don't know what I am talking about and could be pulling this out of my ass. So take it with a grain of salt.
  1. Looooong time GP owner, first time GPF member
    By Brian G in forum Introductions/Noob Questions
    Last Post: 10-02-2013, 06:04 PM
  2. Long time owner/first time poster!
    By brez in forum Introductions/Noob Questions
    Last Post: 08-08-2011, 04:58 PM
  3. Long time reader, first time poster.
    By KeithGTP03 in forum Introductions/Noob Questions
    Last Post: 01-27-2011, 12:55 AM
  4. long time visitor first time poster
    By max98 in forum Introductions/Noob Questions
    Last Post: 05-20-2010, 10:50 PM
  5. first time post long time car owner
    By penstar66 in forum Introductions/Noob Questions
    Last Post: 02-11-2009, 03:54 AM
