GM part is 24508742. The harness that goes from the boost control solenoid, to the fpr, to under the supercharger snout, then around back to the map sensor.
My rubber T under the supercharger snout has disintegrated. Local dealer wants $50 for this assembly and they don't even have it in stock. I've seen it cheaper online, but not by much.
Can't find any rubber tees in stores, just plastic/metal. I've seen references to a thread where someone lists materials to build this harness from standard parts, but I can't find the thread. Anybody know where that thread is, or knows the sizes of vac line and fittings I'd need? I can measure everything after work tonight, but it would be faster if I could just go straight to an auto parts store after work.
