Thread: Stock rocker arm bolt source?
Results 1 to 15 of 15
Threaded View
  1. #14 Re: Stock rocker arm bolt source?
    Mar 2015
    USA
    New 12pt bolts should be here tomorrow. I assume I should still use red locktite on them and torque them to 23ft lbs like the comp ones call for?
    Also, try to torque them with valves closed.
    [edit]
    Just talked to Paul at PRJ. With his bolts he reccomends 25-28ft lbs and using red loctite.
  1. Looking for F-body Banjo Bolt source
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2015, 03:44 PM
  2. rocker bolt sizes
    By ThePhoenix98 in forum General Tech Discussion
    Last Post: 04-14-2014, 11:08 AM
  3. Broken rocker arm bolt
    By Wsmccoy in forum General Tech Discussion
    Last Post: 01-22-2014, 06:35 PM
  4. Rocker bolt help!!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-12-2012, 03:00 AM
  5. Source for stock front sway bar?
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2009, 07:44 AM
