Thread: Issue after intercooler install, car revs high then drops way low
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 98
  1. #1 Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    I just finished with my intercooler install, zzp stage 3 IC, vw radiator. Now when i go to start the car it will run but the idle is all over the place. It keeps reving up to almost 3k then dropping into the 600's where the engine sounds bad and almost dies. It does the same thing if i shift it into neutral. Checked my spark plugs, all my sensors, currently have the MAP unplugged because i was testing the fuel regulator. When the MAP was plugged in it was reading up to 100 KPa when the idle dropped into the 600's. I did not see any codes go off on my scanner.
    For the install i also used a new modified LIM in case that matters.
    Here is one of my scans without map sensor plugged in.
    02 Grand Prix GT Mods' Top Swapped Gen 3, Stage 2 IC, 3.0" MPS, 42# injectors, 1.8 Yella Terra roller rockers, Speed Daddy Headers, CAI, Self Tuned, 180 tstat, ram air hood, front/rear sway bars/and STB's AL 104's, 12' Dual Piston Break kit
  2. #2 Re: Issue after intercooler install, car revs high then drops way low
    sounds like a huge vac leak.
  3. #3 Re: Issue after intercooler install, car revs high then drops way low
    Nov 2013
    Wisconsin!
    What he said ^
  4. #4 Re: Issue after intercooler install, car revs high then drops way low
    I'd say vacuum leak or pcv blocked off
  5. #5 Re: Issue after intercooler install, car revs high then drops way low
    I'll venture a guess you used a garlock gasket or two.
  6. #6 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Only used rvt no gaskets were used between lim and ic and ic to sc.
    I'll keep checking for vac leaks, thanks.
  7. #7 Re: Issue after intercooler install, car revs high then drops way low
    Are you sure you sealed it up good with rtv? Did you change the lim when you installed the ic?
  8. #8 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Where winter never ends
    I agree, huge vacuum leak
    2000 Regal - Winter Beater
  9. #9 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Yeah I changed the lim with the install. Guess I'm pulling it apart and resealing everything.
  10. #10 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Look harder. Dont need to rip it apart, maybe a vaccum line cracked or something
  11. #11 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Took it apart, seems I was weak with the rtv few spots were definitely not sealed, I did double check the vac lines first and found nothing amiss. Thanks for the help, will let you know tomorrow if is runs after I let the rtv dry.
  12. #12 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Look at you Letting it sit lol, I lay the **** down, go inside shower eat and start it haha
  13. #13 Re: Issue after intercooler install, car revs high then drops way low
    That's crap ^^ I lay it down, by the time you have it together enough... turn the key. That's my way.
  14. #14 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    That works too!!! I'm usually just honey lol
  15. #15 Re: Issue after intercooler install, car revs high then drops way low
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    RTV is Aerobic, and dries by air, correct?
    What I did for my blower, is used a lump some of Copper RTV, set the blower on, put all the bolts in by hand then let it set for an hour. So it can dry. Then after an hour or so, I bolted it down tightly and havent had a Vacuum leak from it in about 11 months.
  16. #16 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    That is the wrong way. Surprised that worked lol
  17. #17 Re: Issue after intercooler install, car revs high then drops way low
    Jun 2011
    Worked for me
    In that case, don't take my advice. Lol
  18. #18 Re: Issue after intercooler install, car revs high then drops way low
    This thread title makes me giggle inside......
    Sorry OP classic intercooler vac leak issue here.
  19. #19 Re: Issue after intercooler install, car revs high then drops way low
    Kemmerer, Wyoming
    I've heard of zzp having quality control issues on their intercoolers, so maybe it will need to be sealed better as well.
  20. #20 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Started the car up and it's doing the same thing, only this time there is also a high pitched whine/squeel to go along with it.
  1. How to install your WBS Intercooler
    By machinegunsquid in forum How To Write-Ups/Tech Tips
    Last Post: 07-11-2019, 08:02 PM
  2. 1999 Grand Prix GT Trans revs high
    By pilgrim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 12:42 AM
  3. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  4. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
