Thread: Changing fuel pump on 05'
Results 1 to 14 of 14
  1. #1 Changing fuel pump on 05'
    GXP Level Member
    Mar 2015
    Tomball
    I'm starting to lean twords the fuel pump starting to go out. After checking prices they are around $300 for an OEM and $275 for a reproduction type and the specs aren't very impressive for the replacements. Is it possible to drop like a Walbro 190 LPH pump into the old assembly? I couldn't even find anyone having to replace a pump.
    Thanks
    Jeff
  2. #2 Re: Changing fuel pump on 05'
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Have you run the part number on amazon? I paid like $175 for a '99 gtp pump for my gt, delphi. Haven't ever looked up prices on '04+ pumps, but don't see any reason they'd be much more.
    Don't use airtex whatever you do, will maybe last a year, garbage pumps.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  3. #3 Re: Changing fuel pump on 05'
    GXP Level Member
    Mar 2015
    Tomball
    I'm very Leary of buying on Amazon, at least if I get a Walbro I know what I'm getting. I'm just wondering if I can just replace the pump. I can't see a good pic of what I'll be dealing with. I noticed the airtex pumps had really low numbers.
  4. #4 Re: Changing fuel pump on 05'
    Cibolo, TX
    Amazon is legit, I compare prices between there and rockauto and go with whatever is cheaper. Probably spent around $2k on parts there the last year or so fixing up various stuff.
    I'm sure some '04+ guys will be along to answer your question about pulling the canister apart.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  5. #5 Re: Changing fuel pump on 05'
    SWPA
    Quote Originally Posted by J57ltr View Post
    I've spent thousands of dollars on Amazon over the years and have never had one issue.
  6. #6 Re: Changing fuel pump on 05'
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    I have a walbro 255 i'm getting ready to install sometime this week or next weekend in my 04 comp g. I think i got a pm from you last month about the install.
    I'll let you know how it goes but i'm going to the jy tomorrow to see about finding a venturi canister so i don't have the "don't let it run below 1/4 tank issue". I generally don't run it that low, but with an aftermarket pump i believe you starve it below that level in ours.
    If i can't get the venturi canister, i'm just going to pull out what we got and throw in the new pump. See how it works. May have to fab some tubing or some junk up to make the janky crap work, i'll see.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  7. #7 Re: Changing fuel pump on 05'
    SWPA
    I believe 04 still has the access panel under the rear seat while 05+ does not.
  8. #8 Re: Changing fuel pump on 05'
    Jan 2013
    Raleigh, NC
    Mine has the access behind the seats/in the trunk. I think you're right though stealthee about the 05's.
    Besides that issue, i'll let you know if the pump is just plug and play or if i have to do nasty stuff to it to make it work.
  9. #9 Re: Changing fuel pump on 05'
    ^post a write up when you do.. I'll be upgrading in the future and if I can take some of the guess work out of it I shall
    04 Comp G.
  10. #10 Re: Changing fuel pump on 05'
    Jan 2013
    Raleigh, NC
    will do.
  11. #11 Re: Changing fuel pump on 05'
    GXP Level Member
    Mar 2015
    Tomball
    Stealthee,
    It wasn't me but I'll be interested for sure. I know it can't be that difficult. I have not seen anything other than the pics. I was headed to the jy yesterday but got there too late so I'm going to have to wait till next week. I didn't even know how this "returnless" fuel system worked. I thought that they varied the fuel pump voltage and used a pressure sensor as feedback.
    I have also heard of a resistor being used to drop the current during low demand.
    So I'm a little behind the power curve on some of the 05+ cars. Any info on other systems is appreciated as well.
    Jeff
  12. #12 Re: Changing fuel pump on 05'
    GXP Level Member
    Mar 2015
    Tomball
    I looked on Amazon, but I couldn't find anything cheaper. I went ahead and bit the bullet and bought a new Delphi unit from Rock Auto. I've never used them before either, but at least I'll have it this weekend. I am going to the JY and pick up a few Baro sensors since they are like $100 each new. Just need to figure out what parts will cross.
    Jeff
  13. #13 Re: Changing fuel pump on 05'
    Jan 2013
    Raleigh, NC
    Update for interested parties******
    I just finished installing a walbro 255 in my comp g. I've only driven about ten minutes since the install, but it seems to run good. Pump is louder than stock and works well so far (in very limited use since I finished).
    I didnt really have to hack anything up or do any fancy sh1t to it. Had to splice in the new wiring, but everything else seemed just plug and play.
    I'll do a writeup with the pics I took in a few days once I know its not gonna grenade on me.
  14. #14 Re: Changing fuel pump on 05'
    GXP Level Member
    Mar 2015
    Tomball
    Sweet, I'm going to send I my pump back I just get a 255L after talking to John at Intense.
    Jeff
  1. Replies: 7
    Last Post: 11-05-2014, 10:09 AM
  2. Replies: 5
    Last Post: 06-22-2014, 07:32 AM
  3. 97 GTP fuel pump woes: Rewire stock pump?
    By Powertrike in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:29 PM
  4. 2003 Limited Edition - Installing New Fuel Pump..How To Get The Pump Out?
    By corvettemike in forum General Tech Discussion
    Last Post: 04-07-2012, 10:04 AM
  5. Changing fuel lines
    By JoRoW99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 09:38 AM
