Thread: Changing fuel lines
Results 1 to 11 of 11
  1. #1 Changing fuel lines
    Grand Island, Nebraska
    Ok so my engine bay is a rats nest, and my fuel lines need redone. Id like to switch to stainless braided lines, or anything put the plastic ones. The evap sits in front since thats where it was on the L36. My return fruel line is also kinked. Ive read the write up like 5 times but I have no idea what the guy is talking about. Suggestions?
  2. #2 Re: Changing fuel lines
    Can someone at least tell me what type of fittings i need to connect to the stock fuel rail and then from stainless hose to my regular hose?
  3. #3 Re: Changing fuel lines
    Pull the quotes of stuff you don't understand and I can reword it to make more sense.
    http://www.grandprixforums.net/how-b...nes-41398.html
  4. #4 Re: Changing fuel lines
    Quincy, Mass
    and dont get jegs brand of hose, i can smell gas vapor in my engine bay sometimes.
    and its much easier to do it with the motor out, but still is a pain to do it.
    No more GP 04 Impala SS Indy:
  5. #5 Re: Changing fuel lines
    I assume you use the swagelok fittings to connect from the metal fuel lines? Is there anywhere else to get the same thing? I still cant figure out what fittings to use to connect to the stock fuel rail. If i could find that out I think i could figure out the fittings for the rail connector to the hose and then from the hose to the metal line connector.
  6. #6 Re: Changing fuel lines
    Added the two fuel rail fittings
    RUS-640850
    RUS-640860
  7. #7 Re: Changing fuel lines
    So would this be everything?
    -connects to stock metal fuel line
    (X1) Earl's -6 AN Male to 3/8 in. Tube fitting PN: 165006ERL
    (X1) Earl's -6 AN Male to 5/16 in. Tube fitting PN: 165056ERL
    -connects to stock fuel rail
    Russel RUS-640850 Fuel rail fitting
    Russel RUS-640860 Fuel rail fitting
    -connects to each end of the 2 braided lines
    SUM-220690 Fitting, Hose End, Straight, -6 AN Hose to Female -6 AN, Aluminum, Red/Blue Anodized, Each 4 $9.76
    10 foot of braided hose (any suggestions?)
  8. #8 Re: Changing fuel lines
    What size is the fitting that connects to the EVAP?
  9. #9 Re: Changing fuel lines
    Charles City, IA
    Who has evap? But I think it is a 5/16 line.
    SMGPFC Two Nipple General
  10. #10 Re: Changing fuel lines
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    kind of a thread jack here but what would it take to move the evap?
  11. #11 Re: Changing fuel lines
    Charles City, IA
    Delete it but to move it extend the line going to the engine and move the purge selonoid where ever you want and run the sites to it
  1. changing brake lines
    By mdotson29 in forum Brakes/Suspension/Chassis
    Last Post: 06-24-2011, 12:33 PM
  2. Need help with fuel lines
    By BDEGhost in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-19-2011, 09:28 AM
  3. fuel lines?????
    By boostedgtp2003 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-28-2010, 05:55 PM
  4. SS fuel Lines
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2008, 01:02 AM
