Thread: Stock rocker arm bolt source?
Results 1 to 15 of 15
  1. #1 Stock rocker arm bolt source?
    Mar 2015
    USA
    I was looking for torque specs and I see our rocker arm bolts are TTY. But I can't seem to locate any beside GM.
    Are they re-usable? I'm finding mixed things on this.
    Doesn't Rockauto carry them, or am I searching for the wrong thing?
    [EDIT]
    I'm dumb. I found the re-usable comp bolts 1053B-12 on Summit.
  2. #2 Re: Stock rocker arm bolt source?
    Mercer, Pa
    You can use a grade 8 socket head cap screw. If you don't have a local source the comp bolts from summit aren't priced to bad.
  3. #3 Re: Stock rocker arm bolt source?
    Mar 2015
    USA
    Quote Originally Posted by sseilmnop View Post
    I figured that's all they were. I didn't order them yet, so I'll check out the local hardware store.
    I assume you follow the Comp torque specs of 22ft lbs. Still put red thread locker on them?
  4. #4 Re: Stock rocker arm bolt source?
    May 2008
    Schuyler, NE
    I really really really hate comp cams rocker bolts.
  5. #5 Re: Stock rocker arm bolt source?
    Prjperformance
    04 Comp G.
  6. #6 Re: Stock rocker arm bolt source?
    May 2008
    Schuyler, NE
  7. #7 Re: Stock rocker arm bolt source?
    The Boss Iceman6669's Avatar
    Jun 2011
    Honestly every time I use comp cams rockers bolts I have issues... Even had a couple break shortly after rebuild once.. .Hate them.
    2011 F-150 Yote powered
  8. #8 Re: Stock rocker arm bolt source?
    Mar 2015
    USA
    Prjperformance
    Just ordered. Hopefully the ship quick, this is my holdup now.
  9. #9 Re: Stock rocker arm bolt source?
    Apr 2015
    Columbus, OH
    What's the problem with comp cam bolts? I already bought them. Am I doomed?
  10. #10 Stock rocker arm bolt source?
    I hated them.. Why because they're hex head and were very easy to strip even when torquing them to their correct ft/lbs. and last I checked prj were only $17 shipped and are a 12 point head so it's harder to strip them.
    04 Comp G.
  11. #11 Re: Stock rocker arm bolt source?
    Jan 2009
    Tallahassee, FL
    I used comp cam bolts on my engine over two years ago and I had zero issus putting them in.
    Also any bolt that's TTY is not reusable.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  12. #12 Re: Stock rocker arm bolt source?
    Apr 2015
    Columbus, OH
    The comp cams are only torqued to 23 ft/lbs. Why would they strip easily...even a hex should not be an issue at such low torque.
  13. #13 Re: Stock rocker arm bolt source?
    Yea they strip.. Several of mine stripped and yes they were torqued properly every time.. Even though they're reusable.. After taking them off a few times.. If just became easier and easier to strip them out. Haven't had those issues with the prj ones and they're cheaper! If you already have or ordered the comp cam ones.. Use them. My experience was just a heads up.
    04 Comp G.
  14. #14 Re: Stock rocker arm bolt source?
    Mar 2015
    USA
    New 12pt bolts should be here tomorrow. I assume I should still use red locktite on them and torque them to 23ft lbs like the comp ones call for?
    Also, try to torque them with valves closed.
    [edit]
    Just talked to Paul at PRJ. With his bolts he reccomends 25-28ft lbs and using red loctite.
  15. #15 Re: Stock rocker arm bolt source?
    GT Level Member Overkill's Avatar
    Nanaimo British Columbia
    The PRJ bolts are probably more reliable. Don't use the socket cap "reuseable" bolts in any high leverage situations, I've had enough break to know not to use em
    Email all inquiries to willoverkill@gmail.com!
  1. Looking for F-body Banjo Bolt source
    By buickman104 in forum Brakes/Suspension/Chassis
    Last Post: 06-18-2015, 03:44 PM
  2. rocker bolt sizes
    By ThePhoenix98 in forum General Tech Discussion
    Last Post: 04-14-2014, 11:08 AM
  3. Broken rocker arm bolt
    By Wsmccoy in forum General Tech Discussion
    Last Post: 01-22-2014, 06:35 PM
  4. Rocker bolt help!!!!
    By DaytonaGTP500 in forum General Tech Discussion
    Last Post: 06-12-2012, 03:00 AM
  5. Source for stock front sway bar?
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2009, 07:44 AM
