Thread: Knock
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
  1. #1 Knock
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Using the torque app with knock detector and it is telling me I have no detonation 3.4 pulley short ram intake zzp pcm straight pipe to stock mufflers, nothing else. Is this possible ?
  2. #2 Re: Knock
    GTP Level Member
    Jan 2015
    Lincoln, NE
    No Cat no ubend? Absolutely
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  3. #3 Re: Knock
    Topeka, ks
    Yup
  4. #4 Re: Knock
    Topeka, ks
    Only 91 or 93 octane from time to time half tank of 102
  5. #5 Re: Knock
    Seems hard to believe with nothing other than an intake and ubend delete.
    They always seem to knock with stock manifolds in the higher rpm range.
  6. #6 Re: Knock
    Topeka, ks
    The first time I ram it, it said -.05. every time after it said no detonations found I ran it about 5 times
  7. #7 Re: Knock
    Not saying it's wrong, but I could never trust a phone app to give me data like that.
    The way you say it gives out it's readings just has me thinking it's not doing a real time log down to the tenth of a second.
  8. #8 Re: Knock
    i got the t app and dhp, the t app is pretty dead on.
    he could have one of them factory freaks. or the 102 is killing the kr off.
  9. #9 Re: Knock
    Kemmerer, Wyoming
    Is it unleaded 102, if not your o2 sensors are dying
  10. #10 Re: Knock
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by xxburkettxx07 View Post
    It's probably the ZZP PCM dumping an F-ton of fuel to prevent knock, if I had to take a crack at it.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  11. #11 Re: Knock
    Jul 2012
    Chicago
    Quote Originally Posted by GTP131 View Post
    That was my premise as well.
    OP, what kind of timing do you have at WOT?
    -Carl
  12. #12 Re: Knock
    Topeka, ks
    Now it's saying I do have detonation
  13. #13 Re: Knock
    the engine has to be up to 140 or 160 degrees for the knock sensors to work. so maybe the car was cold still.
  14. #14 Re: Knock
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    How much Detonation do you have now?
  15. #15 Re: Knock
    Jun 2011
    What Scotty said ^
    Personally, I never "beat" on my car until its up to full operating temperature.
  16. #16 Re: Knock
    GTP Level Member
    Jan 2015
    Lincoln, NE
    probably about 6* in that zzp PCM
  17. #17 Re: Knock
    Nov 2011
    NY
    The torque app is accurate, if you don't want a delay, don't load so many gauges in it, limit it to what you need to see. Is real time and I've checked it against other gauges and its dead on. Make sure you have the Knock PID loaded and as mentioned the PCM doesn't monitor knock until @ operating temps. The torque app is just displaying what the PCM sees...
    But the bigger problem is dropping to a 3.4 on a ubend with a box tune (let some a ZZP). Just asking for trouble in my opinion. A wideband would give up the ghosts on the ZZP tune to see of its dumping fuel. But anyways, welding in an extra bung would seem too much work for some!
    Worse that could happen is "BANG" "CLUNK" "CHINK"... Time for a new engine because you thought you had no knock on a ubend delete while dropping pulleys!
  18. #18 Re: Knock
    Topeka, ks
  19. #19 Re: Knock
    if im right judging by your timing. you got like 9* of kr there easy.
    get a better app, or a better screen that tells how much KR your getting.
    i run timing and kr on a screen by themselves.
  20. #20 Re: Knock
    Feb 2013
    Missouri
    Torque knock detector, it's never worked for me. You aren't using the right section. You need to add the additional PIDs for GM vehicles, then add a KR gauge on your dashboard.
  1. knock
    By JROCK1987 in forum General Tech Discussion
    Last Post: 02-13-2012, 05:07 PM
  2. Is it knock?
    By radiocrash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2012, 12:30 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
