Thread: Knock
Results 21 to 40 of 45
  1. #21 Re: Knock
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    What's a better app ? How do I add the additional PIDs
  2. #22 Re: Knock
    if you have the torque app its the best one. only works on a droid system tho.
    http://www.grandprixforums.net/threa...ive-KR-monitor this thread tells you how to add GM pid's
  3. #23 Re: Knock
    Jul 2012
    Chicago
    Good god. I think Scotty is right, stop beating on the car ASAP. If that 6.5 degrees of timing is accurate….
    -Carl
  4. #24 Re: Knock
    Feb 2013
    Missouri
    ^^^exactly, it won't last long with that timing. Your gonna have a chipped piston mod soon. I'm freaking out over 3-4*.
  5. #25 Re: Knock
    i was down to 5* of timing when i had 8* of kr, but i was also stock.
  6. #26 Re: Knock
    Topeka, ks
    Will The 3"down pipe will help with the kr ? What else can I do
  7. #27 Re: Knock
    you should really take that pulley off till you get headers or a 3 inch down pipe and a plog. hint headers are cheaper then the dp/plog combo.
    getting a tune cant hurt either.
  8. #28 Re: Knock
    Topeka, ks
    I already have the down pipe just waiting get in muffler shop to get resonator n mufflers on thinking about a power log now lol anyone have one for sale
  9. #29 Re: Knock
    the dp should help. scrap the res, buy a glass pack have the shop install that in place of the res. they are like 25 bucks at the parts store.
    speed daddy was selling a plog, but ive not seen it in a long while now, it was a 120 iirc.
  10. #30 Re: Knock
    Topeka, ks
    Aren't a resonator n glass pack about the same it is allot shorter than the stock one I paid $40 eBay
  11. #31 Re: Knock
    thats not a bad price really. glass packs come is all lengths, i got a 32 inch glass pack in my car.
  12. #32 Re: Knock
    Topeka, ks
    This one I would say is roughly 24"
  13. #33 Re: Knock
    regals have a longer res then a gp. i measured up my old one, bought one that was close. it was a 30 inches long. so i got a 32 g/p. i cut the inlet tube off welded a flange on it to make it 2 inches shorter over all.
  14. #34 Re: Knock
    Topeka, ks
    Looks good. Can I buy a 2.5" flange at part store or do I need to go to muffler shop
  15. #35 Re: Knock
    its a muffler shop item. cost me 10 bucks. gasket was like 8.
    i got the gasket at the parts store, then matched it to the flanges on the shop wall, cause they all looked dumber then dirt and i didnt want to get screwed.
  16. #36 Re: Knock
    Topeka, ks
    Think I'll have guy at shop I work at weld flange to res. Tom and put dp in maybe this weekend I hate clamping exhaust I have some of these flat exhaust claps never used then before are they worth a crap? Do you know
  17. #37 Re: Knock
    every last pipe connection now has a band clamp on it. once i put the 3.4 pulley on i was blowing sections a part one by one lol
    im up to 6 band clamps now, headers to muffler.
  18. #38 Re: Knock
    Topeka, ks
    Ok I got the kr gauge installed looks like I'm getting between 7* 8*kr only 8psi is that correct on psi?
  19. #39 Re: Knock
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by xxburkettxx07 View Post
    i wouldnt be worried about the boost right now....it would be throwing your 3.8 pulley back on the car or driving like a grandma until you get it tuned properly.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  20. #40 Re: Knock
    SE Level Member Hot wheels's Avatar
    Feb 2015
    Breckenridge TX
    I just bought my PLOG for 139.00 at ZZP ........... It will not give HP like long tube header but frees up some air flow under boost and lowers KR.......... Takes about 30 min to install.
  1. knock
    By JROCK1987 in forum General Tech Discussion
    Last Post: 02-13-2012, 05:07 PM
  2. Is it knock?
    By radiocrash in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2012, 12:30 PM
  3. Listen to the knock knock knock....
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2011, 05:40 PM
  4. Knock Knock - What is it?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2009, 12:28 AM
  5. bad knock...
    By FooteGTP in forum Introductions/Noob Questions
    Last Post: 06-29-2009, 04:35 PM
