Thread: Not Another Coolant Leak Thread?!
Results 1 to 10 of 10
  1. #1 Not Another Coolant Leak Thread?!
    May 2012
    Thunder Bay, Ontario, Canada
    So here's the deal,
    I have a 2007 Grand Prix 3.8L SC with 117000kms. I knew I had a leaking water pump, discovered also leaking tensioner elbows.
    I took the day and replaced the tensioner elbows with aluminum elbows, installed a new bosch water pump, replaced the thermostat 180F. Mixed 70% Coolant/ 30% water. Ran the car for about 45 minutes with the funnel set from Napa to rid air locks.
    For about 3 days to follow I didn't notice a leak per say but I went from a constantly fluctuating temp gauge to a gauge that didn't come passed the 3/8's mark once, except the one time passed half a little when I was bleeding the air locks on first start-up.
    So now 2 weeks later I have a medium leek that seems to worsen when the vehicle is started/pressurized. I thought for sure it could be the lower hose I didn't check prior or when I was doing the water pump. I cleaned up the areas stained by leaks when I changed up the parts mentioned above to make sure everything is ok later on.
    The water pump, the elbows, the thermostat, rad, hoses, heater core hoses, none of it are leaking. I can faintly see a pool of coolant somewhere down on the subframe. It leaks down off the subframe in the mid to far back side on the passenger side.
    I don't have heavy grey exhaust, only for a few seconds on start up on a cold day. No oil in the coolant as far as I can tell and the oil level seems to be fine. There wasn't milk in the oil when I changed it in Dec. I have periods of heat loss in the cabin, temp gauge has gone back to jumping around.
    where the funk can I find the leak? Cant really lift up the car enough to fit under to look.
    2007 Grand Prix GT SE 3.8 S/C "The Black Beauty"
    1994 Chevy C1500 4.3L "One wheeler Peeler"
    love/hate relationship.
  2. #2 Re: Not Another Coolant Leak Thread?!
    Use a mirror and check the back side of the heater hose fittings on the tensioner assembly.
    I had a 07 or 08 in at work that was leaking from there last week. The rubber o-ring failed.
    Just something to check.
  3. #3 Re: Not Another Coolant Leak Thread?!
    May 2012
    Definitely no leak from the Elbows or Hoses, to or from the belt tensioner.
  4. #4 Re: Not Another Coolant Leak Thread?!
    St. Louis
    Maybe check the freeze plugs on the back of the block? Timing cover?
  5. #5 Re: Not Another Coolant Leak Thread?!
    May 2012
    Well i discovered the timing cover is pissing coolant. I'm loosely familiar with how to go about changing the gasket out and replacing the timing chain, anyone know of a video out there i can use as a guide? Preferably a 3.8L application.
  6. #6 Re: Not Another Coolant Leak Thread?!
    I don't know if there is a thead about it, but it's kinda straight forward.
    Pretty much remove everthing for doing a water pump but going 2 steps further and removing the balancer and timing cover.
    Not sure if what you said meant that you were going to replace the timing chain, but I wouldnt even bother as they can last well past 200k miles and further before they might be considered worn.
  7. #7 Re: Not Another Coolant Leak Thread?!
    May 2012
    Ya i only have 117,000 kms on the motor but it just something id ratherdo, replacing the timing chain prematurely instead of screwing around with it later, i think its worth the 80 bucks extra.
    I found pictures of the 3.8L block, all angles, it shows everthing so thats good enough.
    Heres the link if anyone else wants to download the pictures. http://www.rockauto.com/catalog/moreinfo.php?pk=3637944&cc=1433703&jnid=483&jpid=0
  8. #8 Re: Not Another Coolant Leak Thread?!
    is the coolant coming from a bolt? or out the side of the gasket?
    if its leaking at the bolt, take that bolt out, and clean the threads and put thread sealant on the threads and put it back in.
    your 100% sure its not a plastic elbow? you got two, one you can see, and a lower on under the alt near the p/s pump. that one leaks down the fire wall side of the engine.
  9. #9 Re: Not Another Coolant Leak Thread?!
    Dec 2015
    Evansville IN
    Quote Originally Posted by 2007GrandPrixGT View Post
    I have this same issue but i am trying to figure out if it is coming from the bolts or the actual gasket. How do you discover it was coming the cover?
  10. #10 Re: Not Another Coolant Leak Thread?!
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    http://www.amazon.com/Motorad-MT-300.../dp/B0067UE6IY
    Rent one of these from auto-zone, pump it up, and spray soap-water on all your fittings...
    Might be surprised how many leaks you find!
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. Coolant Leak
    By Doogie8044 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-16-2012, 11:32 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant Leak
    By rippemblue2005 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-10-2010, 11:30 AM
  5. L36 Coolant Leak
    By JJ91284 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-14-2009, 03:41 PM
