Thread: What rockers should I run?
Results 1 to 20 of 22
  1. #1 What rockers should I run?
    Jan 2015
    Minnetonka MN
    I have stage 3 zzp heads with an XP hot cam in a supercharged L36 block. What valve spring, pushrods and rockers should I run? Are stock rockers good for this build?
  2. #2 Re: What rockers should I run?
    May 2008
    Schuyler, NE
    Stock rocker, stock pushrods, 130# springs, machined retainers, and viton valve seals.
  3. #3 Re: What rockers should I run?
    What he said ^^
  4. #4 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    Thank you guys. I believe that heads I got came with 130# springs. There is a cam should I still use stock pushrods?
  5. #5 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    I think zzp said longer ones
  6. #6 Re: What rockers should I run?
    Please look at your question.. I'm cornfused
  7. #7 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    Zzproformance wants longer pushrods with the cam I got.
  8. #8 Re: What rockers should I run?
    Nov 2011
    NY
    If you want accuracy, buy the PR tool to measure length, then order them. But really with hydraulic lifters, you're not going to have an issue with PR's. StageIII heads and an XP cam? Hmmmmm... GenV, IC & 1.7 rockers on those heads were recorded (old) around 360whp, switch to an XPZ and go to 400+ (tuned of course)...
    anyways, rockers will dictate lift, lift will dictate springs (barring shift points)... Then add double roller if high lift and you don't list your other mods that are in build? Intake, exhaust, etc., etc...
    start by sharing your PLAN for the build and your expectations, maybe that'll let others help zero in on what you're looking for.
  9. #9 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    Hello guys, I'm Neal Hanson and have been working on my natural aspired 3800. I have some questions for you. So far what have done is had the block bored to 20000 thoudnds over and put in JE Forged pistons (flat top) and rings. H-Beam connecting rods. Crank ground and hardened. X-P Hot cam. Removed the balance shaft and filled the gullys Put on double timing chain set. New oil pump with machined cover. New timing cover. I have ZZP heads stage 3 with the multi layer metal head gasket to put on. What kind of rockers should I use? LS7 lifters. L36 supercharger kit. would the 33# injectors be right for this set up? ZZP Headers with egr delete. What size down pipe should i use? No cat but what would be good to use for exhaust after the down pipe? Should i run an inner cooler? What kind of spark plugs should i run? The super charger has the 3.8 pully can i go smaller and how much? What are your thoughts on this build any concerns? Any tips or suggestions?
    Thanks again.
  10. #10 Re: What rockers should I run?
    Nov 2011
    NY
    Safely Modding Your 3800 Powered Car!!
  11. #11 Re: What rockers should I run?
    Kemmerer, Wyoming
    Quote Originally Posted by Squeallhanson View Post
    Thanks again.
    you are asking a lot of different questions here and need to learn some engine theory. a good place to start is by reading the safely modding your 3800.
    http://www.grandprixforums.net/threa...00-Powered-Car!!
  12. #12 Re: What rockers should I run?
    These two got it.
  13. #13 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    I read over "safely modding your 3800 powered car.. it was vary helpfully thanks guys for the recommendation.. it answered a lot of my questions
  14. #14 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    I will let you know if I have more..
  15. #15 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    What brand of rockers should i get.? I know i have to use stock ratio.
  16. #16 Re: What rockers should I run?
    May 2008
    Schuyler, NE
    Stock rockers!
  17. #17 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    So go right to gm?
  18. #18 Re: What rockers should I run?
    use the rockers that came on your heads. aka stock rockers.
  19. #19 Re: What rockers should I run?
    Jan 2015
    Minnetonka MN
    Even with 150,000 i should use them?
  20. #20 Re: What rockers should I run?
    its what most use. the old stock rockers. so it should be ok.
  1. HARLAND SHARP 1.7ROLLER ROCKERS AND 1.9 modded rockers
    By comp prix in forum For Sale - Parts
    Last Post: 08-02-2014, 11:33 PM
  2. Rockers or a cam?
    By SleeperGS in forum General Tech Discussion
    Last Post: 08-09-2011, 02:18 PM
  3. rockers in a 06 L32
    By reallyfast1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2011, 09:38 AM
