Thread: Help with Rod Replacement... yes I searched.
Results 1 to 20 of 84
  1. #1 Re: Help with Rod Replacement... yes I searched.
    May 2008
    Schuyler, NE
    Your best bet is to find a used L67 rod someplace. I'm not aware of any that you can buy new anymore.
    Whatever you do, don't machine the crank. You will snap it in half if you run a machined crank. You will need to find one that is still within spec.
    Everyone else here has touched on how much you will save by just getting a junkyard motor.
  2. #2 Re: Help with Rod Replacement... yes I searched.
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    Thank you, and noted.
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  1. Ok...searched high and low with no results, so here it is:
    By NCBikerBoy in forum General Tech Discussion
    Last Post: 07-08-2013, 06:10 PM
  2. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
  3. 3.29 Question, and i searched a LOT
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 12:45 PM
  4. HEADER Q''S (searched for but no luck)
    By speed demon in forum General Tech Discussion
    Last Post: 06-14-2012, 12:28 PM
  5. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
