So it turns over, when there are no plugs in the heads, so you have a "vent" so to say, and when you install plugs it turns over once, then does not turn over at all?
The way I am reading this is that your motor basically seizes on you after one engine rotation, and to get it un stuck, you have to pull the plugs.
Is that correct?
~F~
