if i want to remove my supercharger to rough polish it or paint it and remove the fuel rails whats steps do i take? also i would like to remove the valve covers but those just are bolts i think lemme know.... thanks
Unclip all the injectors and remove the 4 nuts that hold the fuel rail on and BE CAREFUL...I snapped 2 of them![]()
you snapped 2 injectors? is it easier to remove the whole fuel rail with the injectors still attached i saw that in a how to they said to slowly pull up on one corner and the injectors will come out with the fuel rail....what do i need to do to relieve fuel pressure?
Remove your gas cap and there is a valve on the front of the fuel rail that you press down. Like a tires valve stem. You can't Miss it. I removed my fuel rail with all injectors still connected to it just fine.
