Thread: Coolant Elbows
Results 1 to 20 of 28
  1. #1 Coolant Elbows
    GT Level Member kissmyss's Avatar
    Jan 2009
    ny
    My alternator tensioner started getting weak, so I replaced it with one I purchased from ZZP. When I purchased the tensioner, I also purchased the coolant elbows from ZZP. I went on a road trip, when I returned I noticed coolant leaking on the ground and the leak was coming from the elbows. I didn't think I would have to change the O rings these before installation, I thought it only applied to the Doorman elbows. Luckily no damage occurred from the lack of coolant. I upgraded to the Doorman aluminum elbows and yes I replaced the O rings before installation.
    ZZP elbows after removal, notice how the O rings are compressed flat.
    Here are the aluminum elbows that were installed and a picture of one that was installed. I couldn't get a clear picture the other one.
    I also replaced the upper and lower radiator hoses. Getting to the lower hose clamps wasn't easy, but I got it done and now all is as it should be.
    05 SS CAI intake, Front & rear STB's, ZZP SS DP wcat, ZZP 180 t-stat, ZZP 3.5 tensioner pulley (both), ZZP S/S ceramic plog with ceramic crossover, Overkill Pcm, Aeroforce triple gauge w/pillar pod, Thrasher 3.4 s/c pulley, MCR 200 amp alternator, PRJ wires, Intense Shift kit, ZZP 1.9 modded rockers, ZZP stage 2 Tb, Extreme Dimensions rear bumper lip.
  2. #2 Re: Coolant Elbows
    they all look flat like that when removed.
  3. #3 Re: Coolant Elbows
    May 2008
    Schuyler, NE
    I run a bead of rtv around them, so I never have a leaking problem.
  4. #4 Re: Coolant Elbows
    The Boss Iceman6669's Avatar
    Jun 2011
    ^^^ Thats exactly what I do also.
    2011 F-150 Yote powered
  5. #5 Re: Coolant Elbows
    ive only oiled the o rings, changed mine twice, once cause they leaked, then just the upper elbow when i did my lim job. as long as the holes are clean no rtv is needed.
  6. #6 Re: Coolant Elbows
    Bastard Reptile's Avatar
    Kansas City, MO
    Well, ok then.
  7. #7 Re: Coolant Elbows
    Oct 2011
    Toledo, OH
    Those look excessively flat for only a few hundred miles. Mine we're not even that flat after 98k miles.
    And why would people need to change the o-rings on the aluminum ones?? They seated just fine and are not leaking for me, I cleaned my holes out and greased them though.
    7"
  8. #8 Re: Coolant Elbows
    the good one i changed for my lim was as flat, the way i look at it is, it had to compress to seal right. why its flat. its still a C hair taller then the elbow.
  9. #9 Re: Coolant Elbows
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    i rtv the f**k out mine 40k miles in one year lots driving very hard driving lol and no ishues
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  10. #10 Re: Coolant Elbows
    SWPA
    You are wasting your time RTVing them. I had several years on my elbows with zero leaks until the elbow itself blew out. I put aluminums in, used no RTV and have no leaks.
  11. #11 Re: Coolant Elbows
    May 2008
    Schuyler, NE
    Damn....I'll never get that 30 seconds back.
  12. #12 Re: Coolant Elbows
    Jun 2011
    My thoughts exactly. 30 seconds of work for years of peace of mind.
  13. #13 Re: Coolant Elbows
    Jan 2009
    ny
    A few years back the Dealer did my Lim under warranty and changed the elbows. Six months later I removed the tensioner to get to the steering pump, the O ring weren't flat and I just re installed the elbows with no leaks . The O rings on these elbows are flush with the groove they ride in.
    Quote Originally Posted by industrialfish View Post
    I changed the O rings just to be on the safe side and didn't want to keep spending on antifreeze.
    Only the purple one is taller and that's the only one that wasn't leaking. I drove the car for two weeks checking for leaks before I went on the road and there weren't any.
  14. #14 Re: Coolant Elbows
    Dec 2008
    Lawndale, CA
    I switched out the o-rings on the aluminum one's I installed on mine. I replaced them with o-rings GM uses. They are a tad bigger. I never had issues with the GM's but the Dorman's I have had issues with the o-rings leaking.
  15. #15 Re: Coolant Elbows
    why would one take the alt bracket off to change a p/s pump?
  16. #16 Re: Coolant Elbows
    Oct 2011
    Toledo, OH
    If for some reason you want to get to it from the top, the hoses going to the heater core are definitely in the way.
    7"
  17. #17 Re: Coolant Elbows
    I've used GM, Dorman and probably some knock off of the knock off brand. Never had a leaking issue. I clean the old corrosion out and use oil or vasoline to lube the new rings so they don't get torn when reassembling.
    If you put RTV in there..then you get to clean it out the next time you want to remove them.
  18. #18 Re: Coolant Elbows
    Jan 2009
    ny
    Some pics from the top with the pump circled in red:
  19. #19 Re: Coolant Elbows
    next time rip it out the bottom of the wheel well, your the only one who's taken that off to do a pump.
  20. #20 Re: Coolant Elbows
    Yeah.. that's the harder coolant flush method of doing the pump.
  1. coolant elbows
    By pittwalleye in forum Introductions/Noob Questions
    Last Post: 12-22-2012, 11:58 PM
  2. coolant elbows. Yes, coolant elbows
    By mainjet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2012, 04:46 PM
  3. coolant elbows
    By pontiaclemon in forum General Tech Discussion
    Last Post: 06-08-2012, 07:16 PM
  4. Ugh.... Coolant Elbows................................
    By chevyy1212 in forum General Tech Discussion
    Last Post: 01-23-2012, 12:34 PM
  5. Coolant Elbows
    By 98GPGT2D in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 05:51 PM
