Thread: top swap wiring
Results 1 to 10 of 10
  1. #1 top swap wiring
    Jul 2014
    New Jersey
    So when doing my top swap is there any special wiring that i will have to add or will i be good, if i dont need it i dont want it basically
  2. #2 Re: top swap wiring
    Mercer, Pa
    There is a boost bypass valve. Not sure how people handle it in a top swap.
  3. #3 Re: top swap wiring
    Donating Users timboku's Avatar
    Montgomery, IL
    Zzp sells the boost bypass seloniod harnass and the map sensor harnass..those are the only difference in wiring when.top swapping.
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  4. #4 Re: top swap wiring
    May 2008
    Schuyler, NE
    And injectors...
  5. #5 Re: top swap wiring
    Jul 2014
    New Jersey
    Injectors are only different on 01+
  6. #6 Re: top swap wiring
    GT Level Member andesmint's Avatar
    Jun 2012
    Minot, Nd
    THe boost bypass vale doesn't need to be wired. Basically the main advantage of having it wired is so the boost will cut out when traction control kicks in while accelerating... So if you absolutely must have that make sure you get the wiring kit and tune for it. Otherwise just leave it unplugged and let the lower nipple on the BBV see atmosphere. Also, the map sensor. You'll need a 2 bar map sensor from either an L67 or an L32. Either will work, however the L67 MAP will require a diff plug than the stock L36 MAP plug, so get an L32 if possible as it has the same plug as the L36 map for some reason.
    2000 GT Mods: HAI, 10.5mm wires, rebuilt 60k motor, ZZP stainless headers, magnaflow mufflers, fresh paint job,L-67 top swap, Ported SC...
  7. #7 Re: top swap wiring
    Jul 2014
    New Jersey
    If i use the l32 map sensor do i need anything to secure it down?
  8. #8 Re: top swap wiring
    Jul 2014
    New Jersey
    if i use the l32 map sensor do i need anything to secure it in place?
  9. #9 Re: top swap wiring
    Jun 2012
    Minot, Nd
    the L-67 has a bracket for the map sensor... i'm not sure who it is or the name of the thread but someone on here has a couple L67 map sensor brackets for sale. just dig around in the first couple of pages of the For sale section and you will find it. otherwise hit up a local junk yard. (the l67 bracket should work just fine i would think) i just have mine ziptied down though lol
  10. #10 Re: top swap wiring
    Jun 2012
    Minot, Nd
    hey i was feeling generous so i found the thread for you. I wont speak on the integrity of the seller as I haven't purchased from him nor do i know him but he claims to have what you need. http://www.grandprixforums.net/threa...Want-Gone-ASAP
  1. 4t65 swap wiring question
    By gambler87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-15-2014, 05:42 PM
  2. DIC Swap Wiring..? (Pics)
    By randomhero69jb in forum Introductions/Noob Questions
    Last Post: 03-17-2013, 07:04 PM
  3. GT top swap wiring question...
    By boosted98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-16-2012, 01:36 PM
  4. Wiring MAP sensor, L67 swap
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2010, 01:04 PM
  5. Top Swap Wiring
    By AlldaySteve1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2010, 01:53 PM
