Thread: 00' GS revs on its own
Results 1 to 20 of 36
  1. #1 00' GS revs on its own
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    Not sure if this is a weather climate thing or not but i've been home in Philly for a few months now from San Diego and on a couple occasions my car idle rpm will raise on its own up to 1500rpm.
    Some scary ****, my foot is no where near the pedal. All I can think of is the air temp being so low and cold, unless my throttle position sensor is acting retarded.
    San Diego temps never went below 60*, so I'm not sure if this is a air temp thing(don't think it is though) or a mechanical issue.
    Anybody experience idle rpm just raising on its own? I personally never seen it happen other than cold mornings on cold start in open loop, which then settles back down as it should
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: 00' GS revs on its own
    only when i had a vac leak. check that your gas pedal cable is moving freely too. the cables can fray up inside and cause issues.
  3. #3 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    Yeah I knew it wasn't a vac leak that's y I didn't mention that but the throttle cable I will recheck. I checked the cable from the throttle side but I have not looked from the pedal end of it. Thanx Scotty....as always
  4. #4 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    In the case that it is frayed, do you use a lil wd-40 or lithium/silicone spray?
  5. #5 Re: 00' GS revs on its own
    if you pull the throttle back to wot at the TB, you can then pull and push the cable in and out. being your holding the cable, you'll feel if theres any binding when you move it.
    when they go bad they tend to leave you with a high idle, or stick wide open. < really sucks.
    i had to drive like 30 miles one time with a string tied to the tb on my 97 gmc, cable started to stick, next day it snapped. had to get to a dealer for the new cable, no parts stores had it in stock. (this was during a work day, over 100 miles from home)
  6. #6 Re: 00' GS revs on its own
    Quote Originally Posted by Dee23 View Post
    if its frayed, you replace the whole cable and its housing, its rather easy really, the gas pedal side just hooks on something like on the tb side but easier.
  7. #7 Re: 00' GS revs on its own
    oh, then theres always a dirty TB can cause this too. if bad enough the flap falls to close all the way.
  8. #8 Re: 00' GS revs on its own
    SE Level Member jimzssei's Avatar
    Sep 2014
    I'm still leaning towards a vacuum leak. The IAC is the only other mechanism that would add air, causing an idle surge. Besides something moving the throttle blade, a vacuum leak is all I can think of.
    there's almost 15 years of wear and tear on those rubber/plastic lines.
  9. #9 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    Yeah the iac is what I meant to say, mines should be fairly clean. I cleaned it not to long ago
  10. #10 Re: 00' GS revs on its own
    Sep 2011
    Canada
    I'm also going to lean towards a vacuum leak. It's colder in Philly than San Diego and the air is thinner. Hoses will retract and even a small pinhole won't be an issue in warm air but can cause issues in colder air. The cold air can also cause cracks in your rubber hoses.
  11. #11 Re: 00' GS revs on its own
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    My car was doing that and it ended up being the lower intake manifold gaskets. So, have a look at your lower intake manifold. Look in the ducks and see if you have water in there or something similar to these.
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SKĀ® 4T65E Transmission Shift Kit, 180* Thermostat
  12. #12 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    Will do, hope it's not the manifold gaskets
  13. #13 Re: 00' GS revs on its own
    Buffalo
    Throttle position sensor? My car ate 2 , 1 stock , one on the zzp n* I bought new
  14. #14 Re: 00' GS revs on its own
    I'm in for TPS as well. Been there.. experienced that.. in a camm'd, IC'd, Rockered, Stage 3 head, Headers, and 3.29's in a built trans car. Fun to hold back with crappy stock Bonneville undersized brakes.
  15. #15 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    Yeah it does it intermittently. Intake gaskets look fine and so does the vacuum hoses. Now I can read the TPS with a scanner correct? Just read the throttle position percentage? But yeah it revs when it wants to, usually to around 1200rpm give or take.
    Car drives fine and starts with ease every time cold start or closed loop
  16. #16 Re: 00' GS revs on its own
    May 2013
    What troubleshooting have you done, so far?
  17. #17 Re: 00' GS revs on its own
    Buffalo
    Dude look at your TPS signal on your scanner when it's acting up
  18. #18 Re: 00' GS revs on its own
    Probably going to read about 5%
  19. #19 Re: 00' GS revs on its own
    Jul 2012
    North Philly
    I was reading around 10% +/-
    Just ordered an ACdelco TPS from Rockauto
  20. #20 Re: 00' GS revs on its own
    One day.. you'll have an issue that I don't know so well. One day.
  1. max revs on stock bottom end?
    By Schwuppes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-26-2014, 10:32 AM
  2. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  3. Revs go up/not changing gears?
    By SUGAR in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-18-2011, 11:07 PM
  4. trans revs out
    By kbmukdk2316 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 11-01-2010, 02:50 PM
  5. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
