whats a realistic expectation for gains on a stock car switching to e85?
About the same as running a tank full of race fuel (100+ octane) every time. You'll kill any knock you have so you'll gain back any timing lost from that.
The best part about running E85 is that you can drop pulley sizes. If you're stock, then you're missing half the point.
Get some headers or at least a downpipe and plog, an MPS, and switch to E85. Then you'll be in business.
im almost certian rockers headers e85 could get down around a 3.2 which is what id like to do with my winter beater.
Ran a 3.5 with rockers and pump gas so yeah adding e85 should get down around that area
Where is the video of zoomer grilling his intercoolers ?
if i put on e85 i would definitely be dropping a few pulley sizes, i would guess a 3.4 would be doable on e85.
with rockers headers and a 3.2 on e85 im guessing thats low to mid 13s?
I would say that you'd have a solid upper 13 second car.
would that set up run on 42# injectors with e85? or would i need o go even bigger
by that setup i mean rockers headers e85 and a 3.2
42's would be plenty for that.
I ran my 42's pretty ragged on pump gas on a 3.0"...
So on corn I'd be just double checking is all...but a 3.2" should be fine if you're not really pushing it that hard.
Since we're talking e85. What is best pump for e85, 60#'s and 2.8 pulley? I'm currently running 42# on stick pump with a 3.0 pulley.
Was that on e85? What were you running for lines and rails?
OK. I have a buddy that was asking about a 255 racetronix pump with stock lines and rails.
we ran our racetronix 255 down to 13.6 to 1 afr at 600whp 18psi/5500rpm with e85...stock "ported" lines/quick connects.
took an 044 inline to fix the fuel starvation....then we broke the IS at 22psi Fuuuuuuuuuq
anything over 500whp is time for a better fuel pump
My buddy moved to Arizona and doesn't have much access to e85, so he's stuck using race fuel.
i finally found my pic of one of the leakiest zzp cores ive come across
you can see and count all of em....straight up no ****s given when applying rtv
this thing had 3 vac leaks and 1 vac/boost to pcv leak
http://i260.photobucket.com/albums/i...y/IMG_1325.jpg
