Thread: what pulley should I be able to run
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
  1. #21 Re: what pulley should I be able to run
    Again show me someone running smaller than a 3.0 on 42# injectors and pump gas.....
    instead of saying wrong or untrue this and that......
    Jayroca had an xp cam ported heads no intercooler gen5 headers and a 3.0 on stock injectors stock tune and it was dangerous to say the least.....
    Hes on E85 now but that's irrelavent here....
  2. #22 Re: what pulley should I be able to run
    I ran smaller than a 3.0" with 42's on pump gas.
    But the timing sucked. If I wanted 15*~ I could have ran a 2.8" all day long.
    Didn't care for it. Sweet spot with high timing and a leaner AFR was a 3.1" for me.
  3. #23 Re: what pulley should I be able to run
    Sep 2014
    NYC
    I run Bosch 42.5 Green Giants, XP cam and intercooled with a 2.9 pulley and 17* with 0 KR on pump gas.
    [IMG][/IMG]
  4. #24 Re: what pulley should I be able to run
    cool any idea what kind of numbers it made? ^^^^
  5. #25 Re: what pulley should I be able to run
    Kemmerer, Wyoming
    What Afr did you run blue guy. I'm pretty sure mine is set to 11.5
  6. #26 Re: what pulley should I be able to run
    Sep 2014
    NYC
    Quote Originally Posted by 98FvckingCrazyVet View Post
    Ran a 12.1 1/4 @111 on street tires, it's about 360hp at the wheels as it sits but I just collected all the parts for the N* Gen V swap to hopefully get me into the 11's......
  7. #27 Re: what pulley should I be able to run
    Quote Originally Posted by SgtMarshal View Post
    We had a commanded 11.0-11.3 if I remember right. It's been a few years.
  8. #28 Re: what pulley should I be able to run
    Quote Originally Posted by JCircs View Post
    Kickass those are some pretty good numbers!
  9. #29 Re: what pulley should I be able to run
    Sep 2014
    NYC
    Thanks, I also had 1.6 60 foot on all 3 runs.
  10. #30 Re: what pulley should I be able to run
    Kemmerer, Wyoming
    gonna put the 3.0" pulley on tomorrow
  11. #31 Re: what pulley should I be able to run
    Kemmerer, Wyoming
    *Update: installed XP cam and Ported L32 Heads. going to try a 2.8.
  12. #32 Re: what pulley should I be able to run
    GTP Level Member buickman104's Avatar
    NYC
    Let us know how it goes!
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  13. #33 Re: what pulley should I be able to run
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by 98SnuggleBunnyVet View Post
    Proved where? He already has 42s why in the hell would he go backwards and put stock injectors in?
    Your out in left field man.....
    actually he is in Gardner, Mass...which actually may be a big field, i dunno. but yeah he is definately smoking crack. BRB, i gotta go change out my 255 for a bosch 044 and throw my stock injectors back on my car so i can make some sick POWA!!
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  14. #34 Re: what pulley should I be able to run
    Kemmerer, Wyoming
    going to change out the o2 sensor when it comes in the mail. my fuel trims have been going up and down between -17 and 12 and I got a P1133 code which is for the o2 sensor. its not the catalytic converter because I put a new one a few months back. trying to get this thing tuned for max power and efficiency. will be scheduling some dyno time in the next month.
  15. #35 Re: what pulley should I be able to run
    May 2008
    Schuyler, NE
    Just thought I'd mention, back in the old days before e85 was around, as long as you stuck with the m90, you wouldn't need anything bigger than 42# injectors. 60's were a decent chunk more back then, so it wasn't really worth it to run them unless you were turbo'd.
    I've had 2 cammed 3.0 pulley cars. I ran stock injectors in them both. Stock pumps as well.
  16. #36 Re: what pulley should I be able to run
    Banned
    CT
    This… I ran stock injectors with a GenV and XP cam.
    Broke into the 11s on race gas too.
    With that said… a lot of the info in this thread makes my head hurt.
  17. #37 Re: what pulley should I be able to run
    Only reason I went to the 42.5'ers was the 2.8"~ area...19~ IPW's were kinda on the edge, IMO. Just did it for the headroom, and ended up back on a 3.0" anyways, lol.
