I know every one is always asking the "what pulley can I run" question, so here I go doing the same thing. right now I have a full size phenolic intercooler, ported gen 3, inlet opened to 75 mm, N* tb, 42 lb injectors, headers, I put a new rotor pack in my gen 3 and it has the gen 5 rotor coating on it, I put in a dynotech built transmission with 7/8's chain and dynotech input shaft, 2500 stall TC from ZZP. right now I have my transmission programmed to hold 2nd gear all the way to 100 mph under 50%+ load. no rockers, cam or head work yet. I also have a Engineered Performance LSD. I have a friend that I've been working with to get the tune dialed in, we are going to install a wideband and then get the wot tuning done. my temp sensor gauge in the lim usually shows the temp is close to ambient. I have a set of L32 heads ported with 90 lb springs and an xp cam that I will be installing this winter sometime.
I have a 3.1 on now with no kr so far, if I continue to see no kr I have a 3.0 to put on. after I put the heads and cam on, what pulley do you guys think will be good?
