Thread: Speed Daddy Header problems. Cross over doesn't fit. what did you guys do?
Results 1 to 8 of 8
Threaded View
  1. #1 Speed Daddy Header problems. Cross over doesn't fit. what did you guys do?
    Oct 2014
    Pennsylvania
    So I have some brand new Speed daddy headers and I have problems. It appears like the front header has to much angle coming out of the collector. If I put the cross over on the front header first it ends up way to high on the other end. If i put it on the rear header first then I can't get the front header to fit into the slip joint at all.
    So who has had this problem? Should I send them back or is this normal? Whats the fix?
    Speed Daddy Header problems. Cross over doesn't fit. what did you guys do? Attached Images
  1. Speed daddy header
    By Juskenny7 in forum Wanted To Buy - Parts
    Last Post: 03-20-2014, 01:55 PM
  2. Couple of specific speed daddy header quesions
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-20-2012, 08:00 AM
  3. Speed daddy header egr issue
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2011, 05:47 PM
  4. Speed Daddy Header install writeup
    By vailskier3 in forum General Tech Discussion
    Last Post: 10-26-2011, 09:28 AM
  5. Exhaust band clamp for speed daddy cross over
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2010, 04:01 PM
