Thread: shift issue
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: shift issue
    I don't think Scotty read what you said.
    So you have third and it feels solid? Sooo look up my user name and trans info and find the shift pattern. You'll see any other gear requires at least one soleniod on. It's time to ohm the solenoids through the connector etc.
  2. #22 Re: shift issue
    good luck, mine was dead. same deal. no codes either.
  3. #23 Re: shift issue
    Oct 2014
    brownstown michigan
    Or fluid flow maybe? If it defaults third unplugged that means 3rd is not controlled electronically
  4. #24 Re: shift issue
    Oct 2014
    brownstown michigan
    Yes it has third! I didnt go drive like a mad man but it works.
  5. #25 Re: shift issue
    Oct 2014
    brownstown michigan
    How could it be a solenoid if all gears but third work? And third has no solenoids on.
  1. Tranny Issue help! 1st shift is slipping/sluggish.2nd and up real quick jerk shift
    By Prixness in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-26-2014, 12:28 PM
  2. 97 gtp misfire/shift issue
    By Wilong in forum General Tech Discussion
    Last Post: 05-08-2012, 07:04 AM
  3. Hard shift issue
    By 7point62 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 08:00 PM
  4. 99 GT 1-2 Shift Issue
    By TeeWX in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-01-2011, 06:43 AM
  5. Shift firmness in 3rd issue
    By PWNED in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-15-2009, 04:26 PM
