Re: shift issue
I don't think Scotty read what you said.
So you have third and it feels solid? Sooo look up my user name and trans info and find the shift pattern. You'll see any other gear requires at least one soleniod on. It's time to ohm the solenoids through the connector etc.
Re: shift issue
good luck, mine was dead. same deal. no codes either.
Re: shift issue
Or fluid flow maybe? If it defaults third unplugged that means 3rd is not controlled electronically
Re: shift issue
Yes it has third! I didnt go drive like a mad man but it works.
Re: shift issue
How could it be a solenoid if all gears but third work? And third has no solenoids on.
