Thread: E85
Results 1 to 20 of 28
  1. #1 E85
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    So I'm making the switch to e85 in November. Just had a quick couple questions. Where is the cheapest to get a fuel pump to run e85. And I have headers and intake. Was trying to figure what pulley I could run with this setup. I was thinking 3.4/3.3. What are your guys thoughts?
    2001 sliver gtp her name is Reagan
  2. #2 Re: E85
    Really?
    Like the 8th thread on E85 in the past 2 weeks.
  3. #3 Re: E85
    Oct 2012
    Fort Wayne, Indiana
    3 in the 5 pages in this section. Non answered it
  4. #4 Re: E85
    there is no set pulley "you" can drop to.
    every car is different, so its as always best to start big and work your way down till it knocks, then if the kr cant be tuned out, you pulley back up a size.
  5. #5 Re: E85
    This.
    Scan scan scan
    That's the only sure fire method that will tell you what YOU can run! Every car is different what works for one guy may not work for another. I suggest grabbed some various pulley when they pop up in the classifieds and go from there then sell whatever ones you don't end up using.
    04 Comp G.
  6. #6 Re: E85
    So what, the info is out there, search harder.
    Walbo 250 and injectors, tune. Done, have a good day and see what it likes. Nothing is set in stone for what you can run.
  7. #7 Re: E85
    Oct 2012
    Fort Wayne, Indiana
    I know the size of the pump I was wondering where the cheapest place was to get one. Looked at venders. Just wondering where to get the cheapest
  8. #8 Re: E85
    Nov 2011
    NY
    Quote Originally Posted by 98buicksupercharged View Post
    Lol... It's almost counter intuitive to ask such a question, you looked at vendors...? They didn't show their prices?
    Well let google be your friend, just look again and note the prices and pick the one who shows the cheapest!!! : )
    lmao... I crack myself up sometimes!
  9. #9 Re: E85
    Arizona
    I hear good things about AEM e85 320 pumps there about 120shipped on amazon.
    Although not sure how that will effect yalls venturi pump for some model years.
    I smell a overall E85 sticky coming soon
  10. #10 Re: E85
    GT Level Member atj8's Avatar
    Midwest
    what are you guys opinions on running e85 in the winter? sorry to thread jack!
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  11. #11 Re: E85
    Cold starts suck. I personally wouldn't run it anywhere it drops to around freezing. Im not saying it freezes but E85 and cold weather sucks.
  12. #12 Re: E85
    Arizona
    E85 works great in the winter or summer. If you tune it right, meaning no putting in some arbitrary IFR value. Set up your fuel right, and bump your cranking spark up a couple of degrees and you wont have an issue. Also E85 DOES change depending on season. from E85- ~E70.
  13. #13 Re: E85
    Quote Originally Posted by 91parkave View Post
    Good luck doing this with a 3800 pcm.
    V8 computers have alot more on the table to work with.
  14. #14 Re: E85
    You ever run E85 in the winter of Arizona? I promise you its nothing like in ND or even DC.
    I started using E85 last Feb while in DC and it takes a while to start when its cold!
  15. #15 Re: E85
    Arizona
    Quote Originally Posted by 98ChainStretcher View Post
    colorado too, lik i said all depends on how you tune your ****. couple extra degrees of cranking spark helps out big time.
  16. #16 Re: E85
    Feb 2009
    flintnasty MI
    91 likes to hear himself talk about how awesome he is.
    Reality is a stock tune with ifr adjustment done will start perfect in any temperature. I used the remote starter in my stock tune 97 gtp through our record setting cold winter last year on a bone stock tune. FACTORY STOCK TUNE.
  17. #17 Re: E85
    Arizona
    Your reality is warped. Its already been proven. And you still need to change your signature cause it its been proven otherwise
  18. #18 Re: E85
    Feb 2009
    flintnasty MI
    You havent proven anything. You sit in arizona and do pointless things to your tune then say it works fine in below zero temps.
  19. #19 Re: E85
    Arizona
    I'm thorough. I respect vacuum vs. Boost in respect to injector flow rate, I respect pulsewidths and the transient fuel effects. I do the research and my tune works great.
    You can use your method. And I'll use mine
  20. #20 Re: E85
    May 2012
    Where winter never ends
    You can tune the car to start in any weather.
    Also, you *can* fit the AEM pump into a non venturi canister. Frost and I have it done right now It just requires modifying the little rubber thing that seals the pump to the canister where the sock comes out. By modifying I mean cutting so it fits. Only down side is you have to be careful when you get down to a 1/4 tank because sharp turns and heavy acceleration will cause fuel starves and the car will die....
    2000 Regal - Winter Beater
