Thread: What pulley vs cam?
Results 1 to 11 of 11
  1. #1 What pulley vs cam?
    gardner,mass
    Wondering if i should run a 3.5 with the vs with higher timing or a 3.4. What do people usually see for timing on there setups with the vs?
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  2. #2 Re: What pulley vs cam?
    Every car is different??
    3.4 to 3.5 makes zero difference in my eyes, we are talking maybe 1ish psi at the most. Pick one and run it.
  3. #3 Re: What pulley vs cam?
    Donating Users Uno99's Avatar
    Appleton, Wi
    I run the 3.4 with 18* of timing @ WOT but im a L67 Gen3
    How much timing are you running on your 3.6 now? any KR?
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  4. #4 Re: What pulley vs cam?
    gardner,mass
    Really your at 18* on a gen3 with the vs and a 3.4? See thats why im wondering. Who said to use a 3.2(gen3) or 3.4(gen5) on a mild cam. Just seems like running higher timing like your setup on a larger pulley would be better.
  5. #5 Re: What pulley vs cam?
    May 2012
    Where winter never ends
    When I was S/C I ran a 2.8/XP/18*....I think a larger pulley and more timing is a better setup then tiny pulley no timing.
    2000 Regal - Winter Beater
  6. #6 Re: What pulley vs cam?
    gardner,mass
    Quote Originally Posted by adecker View Post
    2.8? were you on e85?
  7. #7 Re: What pulley vs cam?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Yes.
    04 GTP -HAI, 1.9 rockers.
  8. #8 Re: What pulley vs cam?
    May 2012
    E85 and IC yeah
  9. #9 Re: What pulley vs cam?
    Aug 2013
    Sandy, UT
    Realistically... you shoulda been able to run a 2.8 without an IC tho aaron... lol e85 + headers + cam + ic = 2.55 blower maxxed out lotsa timing
  10. #10 Re: What pulley vs cam?
    May 2012
    I liked the IC for safeness... and the shiny thing in the front....
  11. #11 Re: What pulley vs cam?
    Appleton, Wi
    Quote Originally Posted by Ginseng View Post
    Ya they say you can run a 3.2 with the VS and supporting mods which I'm sure I could but probably not with that much timing. it's better to run a bigger pulley that is KR free and higher timing than a smaller pulley with KR. I try to run no more than 18* of timing KR free before I go down.
    I say just go 3.4 if it knocks a bit play with the timing and maybe add a bit of fuel where it knocks to combat the KR and she what you can get out of it.
    It you end up.not being able to run it you know you can sell it and you won't be out much cash.
  1. Modular SC pulley and hub, water pump aluminum pulley
    By MattStrike in forum Wanted To Buy - Parts
    Last Post: 03-12-2013, 08:03 PM
