Thread: leaky injector repairable?
Results 1 to 10 of 10
  1. #1 leaky injector repairable?
    Lately I bought a set of used 42.5lb injectors from a seller on the other wbody forum. The info were it was originally purchased from wbs store and flowmatched by DeatschWerks, they're EV1 connectors FWIW. When I got them each one were labeled 1-6 which I imagine the original owner labeled them for each cylinder. Anyways I installed them and when I went to check for leaks via priming the fuel rails, I noticed the one labeled “6” leaked at the area right between the injector itself as it was sealed tightly between the injector and the fuel rail and seated in the head. Below/attaqched is a pic of where I noticed fuel was leaking. I already contacted the seller on Saturday but no response yet :-\
    Is the injector repairable? If so I might as well get them all repaired just in case.
  2. #2 Re: leaky injector repairable?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Contact Deatschwerks, I beleive they do flow testing/cleaning. May do repairs as well. Thats odd I've never seen that.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: leaky injector repairable?
    ^ yea i had sent them an email if they do repairs and such yesterday. just waiting on a response. was curious if something like this is something that happens with injectors. this is a first for me.
  4. #4 Re: leaky injector repairable?
    Aug 2013
    Sandy, UT
    Just slap some duct tape on it and call it good! :-P
  5. #5 Re: leaky injector repairable?
    paypal dispute? these injectors are pretty easy to find. I don't know if it would be worth the hassle just pick up another set, as sucky as that seems its prolly the easiest and least pain in the ass.
  6. #6 Re: leaky injector repairable?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Were these sold as-is? If not, you may want to contact the seller and see if he's willing to be reasonable.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: leaky injector repairable?
    Link to thread
    getting them repaired or getting new ones may be the route to go. i had thought i paid these as good/services on paypal but i did the payment thru the paypal mobile app.
  8. #8 Re: leaky injector repairable?
    Aug 2013
    Sandy, UT
    Even through the app you can choice goods/services or friends family...
  9. #9 leaky injector repairable?
    Quote Originally Posted by SnowTh1ef View Post
    This. Most of the time I use the app unless for w/e reason it's acting retarded.
    04 Comp G.
  10. #10 Re: leaky injector repairable?
    So this is the response i got from a rep for the injectors
    "Unfortunately, that is more than likely a very old set of DW injectors.
    I did speak with one of my techs, and he did state that leaking from the point you circled is not uncommon and is not repairable.
    At this time, that injector has be superseded at least a few times and we would not have a replacement available in inventory.
    The part number we available that should be a close replacement is linked below.
    http://www.deatschwerks.com/products...-0440-6-detail
    Kind Regards"
  1. Leaky Leaky Oil Leak - Update.. Its the pan HELP
    By Yarbeau in forum General Tech Discussion
    Last Post: 09-17-2014, 11:27 AM
  2. Is this repairable? Rust!
    By ekutehacklet in forum Shops and Community Heroes
    Last Post: 06-02-2013, 06:28 PM
  3. Leaky pcv
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-24-2012, 11:09 PM
  4. Leaky ZZP FPR?
    By SDGTP99 in forum General Tech Discussion
    Last Post: 08-31-2011, 07:53 PM
  5. Leaky LIM
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2009, 02:23 PM
