Thread: Near Future Build
Results 1 to 20 of 22
  1. #1 Near Future Build
    GT Level Member m17davis's Avatar
    Orland Park, IL
    So I'm going to be starting a build soon. I'm currently porting and polishing my heads. Than I'm going to get a valve job. I have a Gen V and a LIM im going to throw at it.
    Below are the parts I would like to install.
    Your input would help a lot.
    S1X cam
    Comp cams 140 lbs springs
    Modified retainers
    New seals and locks
    LS7 lifters
    Stock rockers
    Reusable rocker bolts
    Double roller or new stock?
    3.2 mps
    42.5 or 60 lbs injectors
    And possibly meth injection
    Am I forgetting anything?
    Ported Gen III ~ 3.4 ~ HAI ~ 180stat ~ 605's ~ Speed Daddy's ~ SLP Catback ~ A/C delete ~ Aluminum Sub-frame ~ AGX Coilovers ~ Vinnie Spacers ~ Fusebox & PCM Relocation ~ Wire Tuck
  2. #2 Re: Near Future Build
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    140 lb springs are pretty overkill for just an S1X cam... I would do titanium retainers and 105s/130s, Stock lifters are fine, New stock chain, should run E85 and a 2.8 xD but if you're going to stick to 91/93 or w/e then yeah that looks good.
    04 GTP -HAI, 1.9 rockers.
  3. #3 Re: Near Future Build
    Orland Park, IL
    Do you mean leave stock lifters in or buy new stock?
    so E85/Meth/2.8/S1X/130s/60lb/ sounds decent
    any other little things? Like fuel pump rewire?
  4. #4 Re: Near Future Build
    Aug 2013
    Sandy, UT
    E85 or Meth, FWIW meth doesn't have a lot of gains on top of e85. Most people will say "LS7" Lifters are the same or basically the same as stock replacements. So that one is up to you.
    So yeah,
    E85
    2.8 pulley
    s1x
    105/130lb springs
    60 lb injectors
    might need a high flow fuel pump.
    And probably drop to 103/104 autolite spark plugs.
  5. #5 Re: Near Future Build
    Orland Park, IL
    So I have a metal gas tank right? And also for the fuel pump.... it has a venturi port right? 97-00 gtp's do?
  6. #6 Re: Near Future Build
    St. Louis
    How about headers and a tune?
  7. #7 Re: Near Future Build
    Orland Park, IL
    I already have speed daddy headers. I want a intense tune. But zzp is half the distance....
    Which pump would you recommend. I'm going to get a racetronix rewire..
  8. #8 Re: Near Future Build
    buy a new stock timing chain when you throw the cam in. (don't need a double roller)
    s1x with 105# springs and ti retainers.
  9. #9 Re: Near Future Build
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 98ChainStretcher View Post
    Exactly what I'm doing.
  10. #10 Re: Near Future Build
    Orland Park, IL
    What pump would you guys run with a racetronix rewire?. A rewire usually comes with installation guide right?
  11. #11 Re: Near Future Build
    installation of a rewire is cake. its pin B5 in the middle plug it you look at the bottom side of the fuse box under the hood. the other end has pigtails on it for the pump and vehicle side. its simple.
  12. #12 Re: Near Future Build
    Orland Park, IL
    Uh oh. My fuse box is in my center console...
    idk if that makes it easier or harder. Idk what the harness looks like.
    What pump do ppl usually run when they are going to run e85 and racetronix rewire?
  13. #13 Re: Near Future Build
    Orland Park, IL
    What pump should be ran with a racetronix rewire? And where is the best place to get it?
    Also is going to e85 with a metal tank a bad idea
    thanks
  14. #14 Re: Near Future Build
    I would grab a plastic tank from the JY.. Cheap..easily and available.
    04 Comp G.
  15. #15 Re: Near Future Build
    Orland Park, IL
    Well just got to the jy. Looks like they drill a 3/4 inch hole in all the tanks...... wtf
    anyway to plug it?
  16. #16 Re: Near Future Build
    Mar 2014
    Tucson
    I'm sure it's been said before, but why plastic over metal?
  17. #17 Re: Near Future Build
    Rust lol
    04 Comp G.
  18. #18 Re: Near Future Build
    Mar 2014
    Tucson
    Oh pffft! I thought it had something specifically to do with the E85. If that's the case, I should be fine with my 'ol tin tank.
    Rust? What's that!
  19. #19 Re: Near Future Build
    Arizona
    If you're in the jy all tanks will have holes cause they can't be stored with any fuel out there in the yard. So the punch holes to drain. Most of them are still fixable though. When my tank caught a leak back in the day I just ordered one off eBay for 60 bucks shipped.
  20. #20 Re: Near Future Build
    Orland Park, IL
    I wanted to switch to a plastic tank for e85.
    Is is possible to plug it with the jb weld fpr plastics?
  1. Replies: 399
    Last Post: 08-17-2016, 01:35 PM
  2. Need help with some future plans
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 06-24-2012, 12:39 PM
  3. Too Slow, Time for a build (GEN V/N*/L32 Lim build)
    By AmericanSoldier in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2012, 01:54 PM
  4. Future Build Options
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2010, 10:54 PM
  5. Future Build? Perhaps.
    By noreasonwhyy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2010, 03:22 PM
