A little was showing. And it was green, so I assume it is corroded pretty far up the wire. I suppose I should replace it before the starter?
So problem, if I'm not mistaken, the engine isn't grounding properly.
So I ran my jumper cable from the body of the starter up to the negative on the battery. Started the car right up.
Ran the jumper cable from the transmission negative mounts to the battery, just clicks.
So for a temporary fix I ran a cable from the negative battery terminal to the top alternator bolt. Car starts fine now.
So I need to replace my negative wires? However, I believe the transmission is grounding which I assume is why everything else works electrically. The engine just isn't grounding, which the starter grounds to the engine through the bolts that mount it to the motor. So am I on the right track so far?
Your engine and trans are bolted together. The negative cable goes on a stud that holds the engine and trans together, so it's directly connected to the engine.
Your cable is bad, please replace it.
BTW.. when you figure that out.. let's talk about that rotating knock sensor ... cause no part of it should be loose and rotating.
Alright Bill. Now that it is running, I am going to go to Autozone since I have class here shortly. I will replace it, this was just a very short temporary fix until I can run into town as this is the only vehicle at the house right now =/
The rotating knock sensor...this is an old pic, but the plastic part that the electrical plugs into rotates. Turns all around. It shouldn't?
Lol thanks Bill. Both my sensors turn like that =/
As a matter of fact... All 3 do lol
(Been here before, no I do not have 3 on my engine, I have 2 L67's and between the 2 I had 3 knock sensors that were not broke off at the base) =P
What's your question? The diagram is direct from GM, the pic is the way they are in color.
Currently yours is on the wrong side of a gasket.
Yes. Switch those 2 bolts. You have it grounded one bolt too high on the trans.
I was more worried about in the pic of the cable, ie heads in 2 directions? Like has a small piece that comes off right at the beginning. Guess I'm not sure where those ones head.
I don't. Only the big bolts that hold the engine and trans together. Thats I guess why I was told to out them where they currently are. And never gave me problems until now after almost 4 months
