A little was showing. And it was green, so I assume it is corroded pretty far up the wire. I suppose I should replace it before the starter?
So problem, if I'm not mistaken, the engine isn't grounding properly.
So I ran my jumper cable from the body of the starter up to the negative on the battery. Started the car right up.
Ran the jumper cable from the transmission negative mounts to the battery, just clicks.
So for a temporary fix I ran a cable from the negative battery terminal to the top alternator bolt. Car starts fine now.
So I need to replace my negative wires? However, I believe the transmission is grounding which I assume is why everything else works electrically. The engine just isn't grounding, which the starter grounds to the engine through the bolts that mount it to the motor. So am I on the right track so far?
Your engine and trans are bolted together. The negative cable goes on a stud that holds the engine and trans together, so it's directly connected to the engine.
Your cable is bad, please replace it.
BTW.. when you figure that out.. let's talk about that rotating knock sensor ... cause no part of it should be loose and rotating.
Alright Bill. Now that it is running, I am going to go to Autozone since I have class here shortly. I will replace it, this was just a very short temporary fix until I can run into town as this is the only vehicle at the house right now =/
The rotating knock sensor... http://tapatalk.imageshack.com/v2/14...8b76656fed.jpgthis is an old pic, but the plastic part that the electrical plugs into rotates. Turns all around. It shouldn't?
Nope..you found your knock issue :th_thumb-up:
Ps.. enjoy the coolant bath
Lol thanks Bill. Both my sensors turn like that =/
As a matter of fact... All 3 do lol
(Been here before, no I do not have 3 on my engine, I have 2 L67's and between the 2 I had 3 knock sensors that were not broke off at the base) =P
http://tapatalk.imageshack.com/v2/14...935d9380f8.jpg
And is this the proper ground stud? I was told it was, however, that bolt just mounts the transmission case to the transmission body, doesn't it?
Correct location
http://i20.photobucket.com/albums/b2...psfc04a1e9.png
Real life pic
http://i20.photobucket.com/albums/b2...-49-42_955.jpg
That looks really close to the starter. Hmmm
http://tapatalk.imageshack.com/v2/14...bb870264ba.jpg
Mine currently.
http://tapatalk.imageshack.com/v2/14...c8e43fb41e.jpg
Down there underneath my headers is where your pic shows =/
What's your question? The diagram is direct from GM, the pic is the way they are in color.
Currently yours is on the wrong side of a gasket.
The spot GM has it is directly underneath the header, but my transmission looks differently?
The spot in this picture is just a big teansmission bolt on my car.
http://tapatalk.imageshack.com/v2/14...d55376b843.jpg
I assume I have the wrong bolt there
Yes. Switch those 2 bolts. You have it grounded one bolt too high on the trans.
Alright. Shouldn't be too hard to do that. I'll do the switching when I get the new battery cable. Is there a write up on how to replace the negative cable?
Write up for Tom
1. Remove old cable
2. Put new cable in
3. Put tools away.
do you have any bolts where the trans and engine meet that have a stud on them ?
