Thread: Engine codes
Results 1 to 8 of 8
  1. #1 Engine codes
    GTX Level Member 98buicksupercharged's Avatar
    Oct 2012
    Fort Wayne, Indiana
    So two engine codes. Cars stalling randomly while driving.
    P0102 mass air flow or volume air flow a circuit low input
    whats it mean by the volume air flow thing.
    And then hen I have a p1133 heated o2 sensor insufficient switching sensor 1. No clue about that one
    2001 sliver gtp her name is Reagan
  2. #2 Re: Engine codes
    Check your ign fuse under the hood
  3. #3 Re: Engine codes
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Hey, I have the same o2 code as well lol
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Engine codes
    check your fuse too
  5. #5 Re: Engine codes
    Oct 2012
    Fort Wayne, Indiana
    All fuses good
  6. #6 Re: Engine codes
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Vacuum leak
    check the boost bypass valve, map sensor, the little rubber t's around the blower, etc.
    If it really is the maf I got a spare one you can try
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  7. #7 Re: Engine codes
    Insufficient switching: Typically the O2 readings go up and down fast. say 80-100 to 750-800 mV. This is the lean/rich in the exhaust stream that can be seen by the O2. When the code for insufficient pops up, that means the pcm isn't seeing it bounce up and down within the expected parameters.
    MAF code could be a bad maf. I like to tap on them with my finger while the car is running. If it stalls or acts up, replace the maf after you check the wiring/connection.
  8. #8 Re: Engine codes
    Oct 2012
    Fort Wayne, Indiana
    Okay so I was doing some readings last night with the scan tool. Dan and I are thinking my map is bad. I sprayed down all vacuume lines. No jump in idle. And when I scanned it my map sensor reading was low according to dan. Since I don't know what the reading should be
  1. 5 engine codes Where do I Start!
    By ksgunner33 in forum General Tech Discussion
    Last Post: 12-31-2012, 02:37 PM
  2. CEL/SES Engine Light Codes
    By Bio248 in forum General Tech Discussion
    Last Post: 01-03-2012, 09:23 PM
  3. Have 2 engine codes
    By GAFF in forum General Tech Discussion
    Last Post: 02-15-2011, 03:35 PM
  4. Engine codes
    By postalizer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-10-2010, 10:20 AM
  5. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
