Thread: 5 engine codes Where do I Start!
Results 1 to 6 of 6
  1. #1 5 engine codes Where do I Start!
    Dec 2012
    ks
    Hey everyone I’m stuck I have a 04 grand prix that is having a rough problem starting cold. The car just wants to turn over and not start. I have found that if I bump the starter for about 3sec then stop and go at it again it will start right up but if I keep the key turned the first time to long it won’t start strange I know. A little history on the car I bought it on a tow lot sale for a little of nothing and all I have done is replaces the plastic coolant tubes it has 160000 miles. After the car starts it runs fine. One other thing I will mention is it says reduced engine power in the dash. I don’t call myself a auto mechanic by any means but I am an industrial mechanic so I can repair what’s broke I just need help with the diagnosis. I have access to a basic code reader and when I plugged it in this is what I got 0606 Pcm/ecm processor fault p1125 throttle position sensor intermittent p1518 intake manifold runner control (stuck open) b2120 door passenger set switch stuck failure I had the seats out to have them cleaned I’m sure I caused this. Then 2125 throttle pedal position sensor/E circuit P2138 accelerator Pedal position sensor circuit range/performance From my past experience I would guess that there is 1 problem and if it is replaced the rest will be fixed am I correct? My first move was going to be a throttle position sensor but I wanted to get an idea before I start throwing parts at it. Also I cleared the check engine light and it has not came back on after driving 100 miles or so but when I plug the reader in the codes are still there any guidance would be great!
  2. #2 Re: 5 engine codes Where do I Start!
    In Memoriam Rocket468's Avatar
    Yukon, Oklahoma, United States
    Yea i would first start off with the tps fix. Then reset the codes.
    My EX wifes other car is a broom.
  3. #3 Re: 5 engine codes Where do I Start!
    Pull the tb and clean it all up along with all sensors in the tb.
  4. #4 Re: 5 engine codes Where do I Start!
    Dec 2012
    ks
    Would the tb cause this what all is there to clean will i need gaskets
  5. #5 Re: 5 engine codes Where do I Start!
    Donating Users JLiss's Avatar
    Dec 2012
    Aurora, IL
    yes you will need TB gasket if you take it off. AZ should carry that in stock.
    brake cleaner to clean the tb, becarefull with sensors brake cleaner will ruin them. MAF sensor clean would suffice.
  6. #6 Re: 5 engine codes Where do I Start!
    GT Level Member GTX's Avatar
    Apr 2008
    Vallejo,Ca
    you cleared the codes, but they are still showing in the reader? do they clear at all/does the CEL go out? if not, they are hard faults and must be fixed...if the CEL is out with 100 miles and your reading codes...they are pending
    the concerning code to me is the p0606...i would check your harness connectors at the ECM, disconnect them and reconnect them...check your harness...if p0606 comes back...you may need to reprogram your ecm or replace it...check with the dealer to see if you have a software update needed
    p1518 typically only sets with low voltage from the battery or the ecm needs to be reflashed or replaced...also will throw code if TPS1 and TPS2 are out of sync..so you have 3 codes that basically represent the same thing
    start with your harness wiring and ground connections..make sure your battery cables are also tight, after check for a software update for your ecm
    COMP G
  1. Motor died - multiple error codes - clueless where to start looking
    By Skrappi69 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2011, 08:10 AM
  2. erratic idle, stall, one no start... NO CODES!! HELP
    By pur3vil in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2010, 10:06 AM
  3. engine problem codes..were to start lookin for repairs
    By Dragonblaze in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-24-2010, 12:09 PM
  4. 97 GTP engine codes
    By willy4x4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2009, 12:31 PM
  5. Runs bad, won't start...Codes P0401 & P0452
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-03-2008, 06:55 PM
