Thread: 3.4 pulley top swap and only seeing small boost
Results 1 to 17 of 17
  1. #1 3.4 pulley top swap and only seeing small boost
    Jul 2014
    New jersey
    i just recently top swapped my 04 impala ls with a gen 3 blower. i am using stock l67 injectors and i also installed a xp cam with all the necassary mods such as 140# valve springs, DR chain, modded retainers, etc but i also am running a 3.4 MPS. I have all the gauges i need connected and hooked up right but i am not seeing anymore than 4 to 5 psi of boost only when i actually get on the throttle. I'm not 100% sure if those number are right for the pulley size i am running but from my research them seem to be a lil lower than what i was expecting to get. i got my cpm programmed by zzp for the colder t stat and 3.4 pulley with the xp cam and top swap. any help and knowledge on this issue would be greatly appreciated.
  2. #2 Re: 3.4 pulley top swap and only seeing small boost
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Vacuum leak, or bad boost bypass solenoid.
    I had a bad boost bypass solenoid and my car would only build 3.3psi max of boost on a 3.4" pulley with a gen 3. Now with a new bypass solenoid I see roughly 8 - 9psi. At around 80 ish I saw a peak at about 10psi
  3. #3 Re: 3.4 pulley top swap and only seeing small boost
    Aug 2011
    Michigan
    At least thats my best guess for you
  4. #4 Re: 3.4 pulley top swap and only seeing small boost
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    I would think boost bypass solenoid/valve as well. Try pulling off the vacuum line on the BBV that is NOT directly connected to the vacuum port on top of the blower. That usually fixes the issue for most and no adverse affects from doing so
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  5. #5 Re: 3.4 pulley top swap and only seeing small boost
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 97AutoXVette View Post
    You also have to plug that line.
    7"
  6. #6 Re: 3.4 pulley top swap and only seeing small boost
    Aug 2011
    Michigan
    Like right there in the blue? That can be removed from the bypass solenoid and plugged off?
  7. #7 Re: 3.4 pulley top swap and only seeing small boost
    Oct 2011
    Toledo, OH
    No, the long hose on the left of the solenoid, off the T
    7"
  8. #8 Re: 3.4 pulley top swap and only seeing small boost
    Aug 2011
    Michigan
    This line in blue?
    What can happen if the line here is disconnected?
  9. #9 Re: 3.4 pulley top swap and only seeing small boost
    Oct 2011
    Toledo, OH
    Yep, the first pic. Unplug that hose and stick a bolt in it to plug it. If your solenoid is bad, you'll get %100 of your boost back but the car can't disable the boost for TCS or reverse.
    EDIT: I honestly can't figure out what would happen if the smaller hose was off. Even a fully stuck open Bypass solenoid, still plugged into that small hose doesn't stop boost as long as the line from the "T" is plugged.
    7"
  10. #10 Re: 3.4 pulley top swap and only seeing small boost
    Aug 2011
    Michigan
    Quote Originally Posted by industrialfish View Post
    I kinda want to say it ends up causing a lean condition. I can't say that for sure but on my old engine, I had a bad boost bypass solenoid and couldn't figure out what was causing the lack of boost. My dad and I plugged off the line coming left off of the bypass solenoid and I ended up with a lean condition but was able to build full boost.
    This is that engine now though o.O
    I was noticing the spark plugs were getting eaten left and right and found out that engine was toaste.
    Again, not sure whether or not the lean condition was from plugging off that line
  11. #11 Re: 3.4 pulley top swap and only seeing small boost
    Mar 2014
    Cincinnati, OH
    To be clear, you can remove both hoses from the two pictures in post #8. That's what I have done to mine and I have no problems and full boost
    2002 GTP sedan:
  12. #12 Re: 3.4 pulley top swap and only seeing small boost
    Mar 2014
    Cincinnati, OH
    You can in fact just remove the line going from between the "T" coming off the fuel pressure regulator, all the way to the boost bypass valve. I did this and removed the boost bypass solenoid all together with no adverse effects at all. I'll send a picture this coming weekend when I am back by the car (work trip this week). Just plug off the right side of the T and leave the non blower side of the boost bypass valve open to atmosphere so the diaphragm in the valve can still function correctly. No fueling issues from this at all. It will not affect your AFR tables, only prevents the solenoid from being effective under boost cut conditions commanded by the ECU
    2002 GTP sedan:
  13. #13 Re: 3.4 pulley top swap and only seeing small boost
    Jul 2014
    New jersey
    I tried plugging that vacuum line and I did get to 10 psi so I went and bought a new solenoid but then I hooked it all up but I still only see 3 psi...is there any chance my PCM could be messing up the boost cause I checked all the lines and no leaks
  14. #14 Re: 3.4 pulley top swap and only seeing small boost
    Oct 2011
    Toledo, OH
    The solenoid is an open/closed valve only. I'd assume if the PCM was messing up and forcing it open, you wouldn't have any boost at all.
    7"
  15. #15 Re: 3.4 pulley top swap and only seeing small boost
    Mar 2014
    Cincinnati, OH
    ^^Correct.. It is usually either on or off as far as the solenoid goes if I am not mistaken
    2002 GTP sedan:
  16. #16 Re: 3.4 pulley top swap and only seeing small boost
    Mar 2014
    Cincinnati, OH
    Just wanted to show my setup for reference. You can see what I have removed as far as the BBS goes and the vacuum lines. It is running great now with this setup and I see full boost with no issues
    you can see I just use a L-fitting coming off of the fuel pressure regulator to the vacuum line that runs down to the intake manifold under the blower snoute
    2002 GTP sedan:
  17. #17 Re: 3.4 pulley top swap and only seeing small boost
    Apr 2014
    Albuquerque New mexico
    i can get 3 lbs of boost with the solenoid open, i had an incorrectly tuned pcm that didnt have the gtp setup take like it should, so i had no boost display on the dash and the solenoid was open full time, but with the 3.4 pulley i still made 3 lbs of boost
  1. Small pulley and inter cooling
    By rolyat in forum General Tech Discussion
    Last Post: 09-05-2013, 08:22 AM
  2. 2000 silvermist Gtp with l32 swap and small mods
    By MrClean in forum For Sale - Vehicles
    Last Post: 05-30-2012, 01:30 PM
  3. small vacuum or boost leak help
    By Doug 97 gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2012, 02:09 PM
  4. 2000 Gtp with l32 swap and small mods
    Last Post: 04-13-2012, 11:13 PM
  5. Could a small valve cover leak cause a loss of boost on a PCV equipped vehicle?
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 11:57 AM
