Thread: How to get the the cam out?!
Results 1 to 20 of 27
  1. #1 How to get the the cam out?!
    Jul 2014
    Virginia
    How do I get the cam out of the car also I bought some ls7 lifters how do I tell the difference between those and the stockers?
  2. #2 Re: How to get the the cam out?!
    Dec 2013
    ohio
    I dropped the two bolts out of the passenger side sub frame. Had to remove about a quarter inch of metal under wheel well for clearance. Slid right out new one right in. 02 GTP
  3. #3 Re: How to get the the cam out?!
    Jul 2014
    Virginia
    Thanks!
  4. #4 How to get the the cam out?!
    You don't have to do any cutting and I sure as hell don't recommend that.. You just gotta lower the driver side a bit and you'll have room. Get a jack and a stand completely remove the 2 passenger bolts then on the driver side use another jack underneath the subframe and loosen the 2 driver bolts a bit.. But don't losses it to much where the subframe is going to drop.. The jack and stand are just there in case..
    04 Comp G.
  5. #5 Re: How to get the the cam out?!
    I saw a thread once where the guy took a hole saw to the inner fenderwell........
  6. #6 Re: How to get the the cam out?!
    Completely unnecessary....
    04 Comp G.
  7. #7 Re: How to get the the cam out?!
    Feb 2013
    37.295091, -121.930053
    did he use heat or a saw?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: How to get the the cam out?!
    He used a hole saw.
  9. #9 Re: How to get the the cam out?!
    Dec 2013
    ohio
    Hole saw maybe extreme. It's not that hard to drop side of sub frame. Do what you want it's your car.
    Djudge1970
  10. #10 Re: How to get the the cam out?!
    hangover park IL
    the only good option is to pull the motor
    most engines need the rear cover gasket replaced and while you have it out its nice n Easy to do the oil pan the valve covers and all the other gaskets that are probably leaking on a car with 100,000 miles
    ~James~ Psychotic Gearhead
  11. #11 Re: How to get the the cam out?!
    Quote Originally Posted by djudge1970 View Post
    Djudge1970
    I was in no way condoning this method.
    Sent from A Galaxy Far Far Away........
  12. #12 Re: How to get the the cam out?!
    Quote Originally Posted by Turbocharged400sbc View Post
    This.
    Doing a cam install without pulling the motor, IMO is a billion times harder than doing it with the motor sitting on a stand. And like stated it gives you the ability to easily address the crap factory gasket set.
    Do it right, or don't bother. You cheap out and half ass stuff, and you'll get that same half assed reliability.
  13. #13 Re: How to get the the cam out?!
    Jul 2014
    Toledo, Ohio
    So do you guys replace the cam bearings when you change your cam on a used engine? Just curious. I know I wouldn't but I have seen plenty of people do that.
  14. #14 Re: How to get the the cam out?!
    To do the cam bearings requires the special tool and removing the crank typically.
    I for one do not change them. Likely they should be.
  15. #15 Re: How to get the the cam out?!
    Mar 2012
    NC
    The cam bearings CAN be done in car...without pulling the crank...just like doing a cam swap... However, it's a GIANT PITA and I don't recommend it. I also recommend letting a machine shop do it out of simplicity sake. You take them the engine and most shops will do the bearing install for less than $100.
  16. #16 Re: How to get the the cam out?!
    FWIW once upon a time a guy posted and gave us some helpful advice.
    If the motor is out of the car, turn it upside down with the rockers and pushrods out. Spin the crank once or twice and the lifters will push up and out of the way. You can do the cam w/o pulling the lifters this way.
  17. #17 Re: How to get the the cam out?!
    hangover park IL
    yeah but if you don't pull the lifters how do you know if you don't have any damaged rollers ready to chew up the new cam....
  18. #18 Re: How to get the the cam out?!
    You inspect the old cam.
  19. #19 Re: How to get the the cam out?!
    hangover park IL
    roll the wheel of a 100k lifter next to a new/low mile lifter.
    and even if you dont replace em, you might as well pop em apart and clean all the sediment out of the checkball
  20. #20 Re: How to get the the cam out?!
    Jul 2014
    Toledo, Ohio
    Quote Originally Posted by sleepy3103 View Post
    Sorry I meant to say I would replace them while I was in there. I would also replace the lifters and pushrods. I have put a cam in a buddies car without replacing lifters because he couldn't afford it and didn't want to wait. A week later one of them collapsed and it was clacking away. Had to pull it apart again.
