Gm cars used both, the majority use a external physical flex fuel sensor with a alcohol %table to adjust the stoich.
Gm tried using a virtual flex fuel algorithm for a couple years but went back to a physical sensor.
Keep in mind with that the car needs to have a voltage input based off of stomach that changes the master stomach table for the car to run correct.
I find it easier just to reflash the car between summer/winter blend
